The record-breaking VN series gives first-time users the ideal combination of simplicity and features for their first voice recorder. The additions to the PC-compatible range make it simpler than ever to record and play back for leisure or work - with bigger full-dot displays, easy-to-use recording modes and double the memory. Users will quickly get to grips with features normally only available on high-end models. With long battery life and an enhanced ergonomic design, the PC-compatible newcomers are ideal for capturing and sharing everything from lectures to holiday sound bites and notes-to-self.
- Olympus VN-8500PC DNS - voice recorder
- Product Type
- Voice recorder flash based
- Enclosure Colour
- Black, white
- 3.9 cm x 1.7 cm x 10.8 cm
- 66 g
- Playback Digital Standards
- WMA
- Sound Output Mode
- Mono
- Digital Recording Time
- 67 hours - HQ (High Quality), 131 hours - SP (Standard Play), 421 hours - LP (Long Play)
- Display
- LCD 1.61"
- Internal Memory
- 1 GB
- Speakers
- 1 x speaker - built-in
- Microphone
- Microphone - built-in - mono
- Interface
- USB
- Battery
- AAA type - rechargeable
- Product Type
- Voice recorder
- Digital Player Type
- Flash based
- Enclosure Colour
- Black, white
- Enclosure Material
- Plastic
- Interface Supported
- USB
- Audio Formats
- WMA
Audio System
- Internal Memory
- 1 GB
- File System Supported
- 1 GB
- Sound Output Mode
- Mono
- Functions
- Digital voice recorder
- Voice operated recording
Display
- LCD
- Display Illumination
- Display Illumination Colour
- White
- Diagonal Size
- 1.61"
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Chinese
- Adjustable contrast
Speaker System
- Speakers
- Driver Details
- Speaker: 1 - 1.1"
Digital Player (Recorder)
- Recording Time
- Data Storage Capability
- Up to 200 messages / 5 folders
- Sample Rate
- 44.1 kHz
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm) , USB
- Software
- Dragon NaturallySpeaking 10 Recorder Edition
- Battery
- Included Qty
- 2
- Battery Life Details
- Voice recording - up to 51 hour(s)
- 3.9 cm
- 1.7 cm
- 10.8 cm
- 66 g
Olympus VN-8500PC Dictation Device with Voice Recognition Software
