Olympus VN-731PC 2Gb Digital Voice Recorder with DNS Grey
Quicklinx: B9RKWS00 Mfr#: V405232TE000
With two different display modes, even beginners will find this voice recorder easy to use. Simple mode displays only essential information in large font and limits the menu options to frequently-used functions, while for advanced users, normal mode offers full functionality of the menu options.
A large diameter, omni-directional, low-noise microphone records sound from all directions. With less noise and reduced breath sound, this recorder is perfect for dictations.
  • Equally perfect for advanced
  • Designed to capture every tone
  • Convenience and clarity in every recording
    A built-in stand on the back of the recorder makes desktop use even easier. It helps to reduce surface noise and keeps your recordings perfectly clear.
  • Optimized settings for optimal results
    Make sure your recordings are fail-safe by choosing the scene in which you want to record. Your recorder then instantly sets the optimal recording parameters.
Olympus VN-731 PC - voice recorder
Voice recorder flash based
Enclosure Colour
Gunmetal gray
3.9 cm x 1.68 cm x 10.8 cm
71 g
Playback Digital Standards
WMA
Sound Output Mode
Stereo
Output Power
320 mW
Digital Recording Time
126 hours - HQ (High Quality), 790 hours - LP (Long Play)
Display
LCD - 108 x 84 - monochrome
Audio Specifications
Digital Player - response bandwidth: 70 - 13000 Hz
Internal Memory
2 GB
Speakers
1 x speaker - built-in - 320 mW
Microphone
Microphone - built-in - omni-directional
USB 2.0
2 x AAA type
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
Enclosure Colour
Gunmetal gray
Enclosure Material
Plastic
Interface Supported
USB 2.0
Audio Formats
WMA
Audio System
Internal Memory
2 GB
File System Supported
2 GB
Sound Output Mode
Stereo
Functions
Digital player, digital voice recorder
Digital Player - response time: 70 - 13000 Hz
Alarm Wake-Up Modes
Beep
Hold button, on/off switch, built-in speaker, low-cut filter, built-in microphone, integrated fold-out stand
Amplifier
Output Channel Qty
1 channels
Output Power / Total
320 mW
Display
LCD - monochrome
Display Illumination
Display Illumination Colour
White
Resolution
108 x 84
Display Menu Language
Danish, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Chinese
Speaker System
Speakers
Driver Details
Speaker: 1 - 1.1"
Digital Player (Recorder)
Recording Time
Data Storage Capability
Up to 200 files / 5 folders
External Hard Drive Function
A-B repeat
Microphone
Microphone Operation Mode
Omni-directional
Connector Type
Microphone , Headphones , USB 2.0 (4 PIN USB Type A)
USB cable
Software
Dragon NaturallySpeaking
2 x AAA type
Included Qty
2
Run Time (Up To)
100 hour(s)
Battery Life Details
Digital recording - up to 100 hour(s) , Digital playback - up to 75 hour(s)
Microsoft Windows XP SP2 or later, Microsoft Windows Vista / 7 / 8, Apple MacOS X 10.5 - 10.9
3.9 cm
1.68 cm
10.8 cm
71 g
