With two different display modes, even beginners will find this voice recorder easy to use. Simple mode displays only essential information in large font and limits the menu options to frequently-used functions, while for advanced users, normal mode offers full functionality of the menu options.
A large diameter, omni-directional, low-noise microphone records sound from all directions. With less noise and reduced breath sound, this recorder is perfect for dictations.
Equally perfect for advanced
With two different display modes, even beginners will find this voice recorder easy to use. Simple mode displays only essential information in large font and limits the menu options to frequently-used functions, while for advanced users, normal mode offers full functionality of the menu options. -
Designed to capture every tone
A large diameter, omni-directional, low-noise microphone records sound from all directions. With less noise and reduced breath sound, this recorder is perfect for dictations. -
Convenience and clarity in every recording
A built-in stand on the back of the recorder makes desktop use even easier. It helps to reduce surface noise and keeps your recordings perfectly clear. -
Optimized settings for optimal results
Make sure your recordings are fail-safe by choosing the scene in which you want to record. Your recorder then instantly sets the optimal recording parameters.
- Olympus VN-731 PC - voice recorder
- Product Type
- Voice recorder flash based
- Enclosure Colour
- Gunmetal gray
- 3.9 cm x 1.68 cm x 10.8 cm
- 71 g
- Playback Digital Standards
- WMA
- Sound Output Mode
- Stereo
- Output Power
- 320 mW
- Digital Recording Time
- 126 hours - HQ (High Quality), 790 hours - LP (Long Play)
- Display
- LCD - 108 x 84 - monochrome
- Audio Specifications
- Digital Player - response bandwidth: 70 - 13000 Hz
- Internal Memory
- 2 GB
- Speakers
- 1 x speaker - built-in - 320 mW
- Microphone
- Microphone - built-in - mono, omni-directional
- Interface
- USB 2.0
- Battery
- 2 x AAA type
- Product Type
- Voice recorder
- Digital Player Type
- Flash based
- USB Specification Version and Speeds
- USB 2.0
- Enclosure Colour
- Gunmetal gray
- Enclosure Material
- Plastic
- Interface Supported
- USB 2.0
- Audio Formats
- WMA
Audio System
- Internal Memory
- 2 GB
- File System Supported
- 2 GB
- Sound Output Mode
- Stereo
- Functions
- Digital player, digital voice recorder
- Digital Player - response time: 70 - 13000 Hz
- Alarm Wake-Up Modes
- Beep
- Hold button, on/off switch, built-in speaker, low-cut filter, built-in microphone, integrated fold-out stand
Amplifier
- Output Channel Qty
- 1 channels
- Output Power / Total
- 320 mW
Display
- LCD - monochrome
- Display Illumination
- Display Illumination Colour
- White
- Resolution
- 108 x 84
- Display Menu Language
- Danish, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Chinese
Speaker System
- Speakers
- Driver Details
- Speaker: 1 - 1.1"
Digital Player (Recorder)
- Recording Time
- Data Storage Capability
- Up to 200 files / 5 folders
- External Hard Drive Function
- A-B repeat
Microphone
- Microphone Operation Mode
- Mono, omni-directional
- Connector Type
- Microphone , Headphones , USB 2.0 (4 PIN USB Type A)
- Included Accessories
- USB cable
- Battery
- 2 x AAA type
- Included Qty
- 2
- Run Time (Up To)
- 100 hour(s)
- Battery Life Details
- Digital recording - up to 100 hour(s) , Digital playback - up to 75 hour(s)
- OS Required
- Microsoft Windows XP SP2 or later, Microsoft Windows Vista / 7 / 8, Apple MacOS X 10.5 - 10.9
- 3.9 cm
- 1.68 cm
- 10.8 cm
- 71 g
