The VN-541PC is the latest addition to the VN series intended for beginners using a digital voice recorder for the first time. Similar to previous VN series recorders, the VN-541PC is engineered for smart functionality, intuitive operations, and one-touch recording. This model includes a one-touch slide switch for an even faster performance.
Clear audio capture
The VN-541PC is equipped with a built-in mono microphone that ensures quality audio recordings suitable for various scenarios, whether at home or in professional settings. -
Ample storage capacity
With 4 GB of built-in flash memory, this device can store a significant number of recordings, ensuring users have enough space for their audio needs. -
Easy-to-read display
The monochrome LCD display simplifies navigation through files and settings, making it user-friendly for individuals of all technical skill levels. -
Customizable recording options
Featuring microphone sensitivity selection and a recording scene select function, the VN-541PC allows users to adapt their recordings based on the environment, ensuring clear audio quality. -
Convenient playback options
The built-in speaker provides sound output for immediate playback of recordings, eliminating the need for external devices while enhancing user convenience.
- Olympus VN-541PC - voice recorder
- Product Type
- Voice recorder flash based
- Bundled with
- Olympus ME-52W monaural microphone
- 3.75 cm x 2 cm x 10.8 cm
- 67 g
- Playback Digital Standards
- WMA
- Sound Output Mode
- Mono
- Display
- LCD monochrome
- Internal Memory
- 4 GB
- Speakers
- 1 x speaker - built-in - 200 mW
- Microphone
- Microphone - built-in - mono
- Battery
- 2 x AAA type Alkaline
- Product Type
- Voice recorder
- Digital Player Type
- Flash based
- Bundled with
- Audio Formats
- WMA
Audio System
- Internal Memory
- 4 GB
- File System Supported
- 4 GB
- Sound Output Mode
- Mono
- Functions
- Digital player, digital voice recorder
- Playback speed control, microphone sensitivity selection, recording scene select, noise cancelling microphone
Display
- LCD - monochrome
Speaker System
- Speakers
- Driver Details
- Speaker: 1 x full-range driver
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm)
- Carrying Case
- Soft case
- Included Accessories
- Micro-USB cable
- Battery
- Included Qty
- 2
- Run Time (Up To)
- 60 hour(s)
- Battery Life Details
- Digital recording - Alkaline - up to 60 hour(s) , Digital playback with headphones - Alkaline - up to 46 hour(s)
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.5 - 10.11
- 3.75 cm
- 2 cm
- 10.8 cm
- 67 g
