Olympus VN-541PC 4GB Black Digital Voice Recorder inc DNS12 Software
Quicklinx: CWCLWS00 Mfr#: V405281BE030
The VN-541PC is the latest addition to the VN series intended for beginners using a digital voice recorder for the first time. Similar to previous VN series recorders, the VN-541PC is engineered for smart functionality, intuitive operations, and one-touch recording. This model includes a one-touch slide switch for an even faster performance.
  • Clear audio capture
    The VN-541PC is equipped with a built-in mono microphone that ensures quality audio recordings suitable for various scenarios, whether at home or in professional settings.
  • Ample storage capacity
    With 4 GB of built-in flash memory, this device can store a significant number of recordings, ensuring users have enough space for their audio needs.
  • Easy-to-read display
    The monochrome LCD display simplifies navigation through files and settings, making it user-friendly for individuals of all technical skill levels.
  • Customizable recording options
    Featuring microphone sensitivity selection and a recording scene select function, the VN-541PC allows users to adapt their recordings based on the environment, ensuring clear audio quality.
  • Convenient playback options
    The built-in speaker provides sound output for immediate playback of recordings, eliminating the need for external devices while enhancing user convenience.
Olympus VN-541PC - voice recorder
Voice recorder flash based
3.75 cm x 2 cm x 10.8 cm
67 g
Playback Digital Standards
WMA
Sound Output Mode
Mono
Display
LCD monochrome
Internal Memory
4 GB
Speakers
1 x speaker - built-in - 200 mW
Microphone
Microphone - built-in - mono
2 x AAA type Alkaline
Voice recorder
Digital Player Type
Flash based
Audio Formats
WMA
Audio System
Internal Memory
4 GB
File System Supported
4 GB
Sound Output Mode
Mono
Functions
Digital player, digital voice recorder
Playback speed control, microphone sensitivity selection, recording scene select, noise cancelling microphone
Display
LCD - monochrome
Speaker System
Speakers
Driver Details
Speaker: 1 x full-range driver
Microphone
Microphone Operation Mode
Mono
Connector Type
Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm)
Micro-USB cable
Software
Dragon NaturallySpeaking 12
Included Qty
2
Run Time (Up To)
60 hour(s)
Battery Life Details
Digital recording - Alkaline - up to 60 hour(s) , Digital playback with headphones - Alkaline - up to 46 hour(s)
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.5 - 10.11
3.75 cm
2 cm
10.8 cm
67 g
