The Tough TG-4 is rugged enough to go anywhere, but its powerful imaging technology makes this camera very versatile. Sophisticated features like RAW capture, nighttime Live Composite, and the super-bright wide-angle zoom lens create amazing images no matter how challenging the environment, while built-in Wi-Fi, fast GPS, and the multifunction compass help you to find, shoot, and share your adventures like never before.
Rugged technology
Whether you snorkel or surf, ride or ski, bike or hike, or love to shoot outdoors, the TG-4 is up to the challenge. It's waterproof, and its rugged inner and outer chassis construction protects the lens assembly from force and impact. Plus, the TG-4 is freeze proof and dustproof, so there's never a reason to leave it at home. -
RAW power
TG-4 captures lifelike images with an unmatched combination of features. You can shoot in RAW for high resolution and maximum creative control. With Olympus' advanced BSI CMOS Sensor and the TruePic VII image processor, you will capture small details and bright colors of every exciting moment. -
Fast and bright
Always be ready to shoot. TG-4's high-speed wide-angle lens captures light fast, and the lightning-quick FAST AF technology keeps the focus sharp. Nail blur-free shots as quick as the action happens, and shoot crisp, detailed images with minimal noise in low light. Plus, the Aperture Priority Mode expands your focus range and shooting control for amazing results. -
Advanced shooting modes
Advanced shooting modes are readily at your fingertips via the Mode Dial. Powerful Macro Modes shoot close, like the Microscope Control mode. Underwater Modes shoot crystal clear, including the Underwater HDR mode that uses composite technology to enhance light and shadow. Nighttime Live Composite mode automatically combines multiple images into a single photograph for stunning night scenes and star trails. -
Shoot anywhere, share everywhere
Find your adventure and find your way back! GPS pinpoints your location in a few seconds, while the compass tracks barometric pressure, altitude, and water depth as it points the way home. With built-in Wi-Fi, share your shots.
- Olympus Stylus Tough TG-4 - digital camera
- Product Type
- Digital camera - 1080p - compact
- Memory Card Slot
- SD card
- Image Processor
- TruePic VII
- Sensors
- Magnetometer, pressure sensor
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 16.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 4x zoom - 4.5 - 18 mm - f/2.0-4.9
- Focus Adjustment
- Automatic
- Min Focus Distance
- 10 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (image sensor shift mechanism)
- Camera Flash
- Built-in flash
- Display
- LCD display - 3"
- Supported Battery
- Olympus Li-92B Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 11.15 cm x 3.12 cm x 6.59 cm
- 247 g
- Product Type
- Built-in Light
- LED lights
- Enclosure Colour
- Black
- Sensor Resolution
- 16.0 Megapixel
- Optical Sensor Type
- BSI-CMOS
- Total Pixels
- 16,800,000 pixels
- Effective Sensor Resolution
- 16,000,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 6400
- Optical Zoom
- 4x
- Digital Zoom
- 4x
- Image Processor
- TruePic VII
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Navigation
- GPS receiver
- Sensors
- Print Standard
- DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Face Detection
- Advanced Face Detection technology, face-priority AF function
- Digital Video Format
- AVI, MJPEG, H.264, MOV
- Image Recording Format
- JPEG, RAW
- 1920 x 1080
- Interface
- Composite video/audio, HDMI, USB 2.0, Wireless LAN
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 6400, ISO 3200, ISO auto
- Exposure Metering
- Multi-segment, spot
- Exposure Modes
- Programme, automatic, aperture-priority
- Shooting Programs
- Landscape, portrait mode, beach/snow, night portrait, self-portrait, fireworks, panorama assist, night scene, Underwater, sports mode, sunset, indoor, cuisine, snow, documents, e-portrait, handheld starlight, backlight correction HDR, microscopic macro
- Bracketing Modes
- Focus bracketing
- Special Effects
- Vivid, fisheye, soft focus, natural, Muted, Diorama, Grainy Film, Pop Art, Pale & Light Colour, pin hole, dramatic, Reflection, Fragmented
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, sunlight, tungsten light, Underwater
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 4 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 25 - 100mm
- Focus Adjustment
- Automatic
- 10 cm
- Macro Focus Range
- 1cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 7 groups / 9 elements
- Filter Size
- 40.5 mm
- Built-in lens shield, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator
- Effective Flash Range
- 0.2 m - 7.9 m: ISO 1600 (wide lens) , 0.2 m - 3.1 m: ISO 1600 (tele lens)
Additional Features
- Continuous Shooting Speed
- 5 frames per second, 15 frames per second (3MP), 60 frames per second (3MP)
- Self-Timer Delay
- 2sec, 12sec, 1 - 30 sec
- Additional Features
- Audio recording, built-in speaker, RGB primary colour filter, date/time stamp, histogram display, AF lock, cropping an image, resizing an image, in-camera red-eye fix, interval shooting mode, USB charging, Shadow Adjustment Technology, tap control, Intelligent AUTO (iAUTO), high-speed recording, Time-Lapse recording, Super Resolution Zoom
Display
- 3" LCD display
- Display Format
- 460,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 , HDMI output (19 pin micro HDMI Type D) , Composite video/audio output
Software
- Software
- Drivers & Utilities, Olympus Viewer 3
- Included Accessories
- AC power adaptor, USB cable, wrist strap
- Protection
- Waterproof, crushproof, freezeproof, shockproof, dust-resistant
- Underwater Use
- Underwater Depth
- Up to 15 m
- Battery Type
- Olympus Li-92B Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 380 shots , Video recording - 2 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Image Storage
- JPEG 4608 x 3456 , JPEG 3264 x 2448 , JPEG 2048 x 1536 , JPEG 640 x 480 , RAW 4608 x 3456
- 11.15 cm
- 3.12 cm
- 6.59 cm
- 247 g
- -10 °C
