Buying a new compact camera can be like getting a new pair of sunglasses - you spend a lot on something impressive only for it to break the first time you drop it. Which is why Olympus developed TOUGH. Shockproof, waterproof and freezeproof, the new OLYMPUS TOUGH TG-320 comes with a worry-free guarantee. Not only is it virtually indestructible, it's also soft on your budget. For little money you get a camera with everything you need to capture HD movies and still photos in 14-Megapixel quality. A hard glass lens barrier safeguards the precision 3.6x wide optical zoom lens (28-102mm) and when you don't have to worry about damaging high-grade components like this, using your camera is suddenly a lot more fun. The TG-320 compensates with Dual IS, reducing blur in poor light and with fast-moving shots. Other Automatic aids on the TG-320 include Intelligent Auto Mode (i-Auto) and AF Tracking that help ensure even hectic scenes come out bright and sharp.You can get creative with 3D underwater photo shooting or Magic Filters and share your shots wirelessly via an Eye-Fi card that automatically uploads stills and movies to a website or PC. With the TG-320, everyone can afford the look they want - no matter how butter-fingered or talent-free. For a camera in this price category, the spec and build quality are both exceptional.
- Olympus Tough TG-320 - digital camera
- Product Type
- Digital camera - compact
- Memory Card Slot
- SD card
- Image Processor
- TruePic III+
- Internal Storage
- 19.5 MB
- Sensor Resolution
- 14.0 Megapixel
- Max Video Resolution
- 1280 x 720
- Lens System
- Zoom lens - 3.6x zoom - 5 - 18.2 mm - f/3.5-5.1
- Focus Adjustment
- Automatic
- Min Focus Distance
- 50 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (image sensor shift mechanism)
- Camera Flash
- Built-in flash
- Display
- LCD display - 2.7"
- Supported Battery
- Li-ion rechargeable battery (included)
- Interface
- USB 2.0
- Blue
- 9.6 cm x 2.3 cm x 6.3 cm
- 155 g
- Product Type
- Enclosure Colour
- Blue
- Sensor Resolution
- 14.0 Megapixel
- Optical Sensor Type
- CCD
- Total Pixels
- 14,500,000 pixels
- Effective Sensor Resolution
- 14,000,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 1600
- Optical Zoom
- 3.6x
- Digital Zoom
- 4x
- Image Processor
- TruePic III+
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Print Standard
- DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Face Detection
- Advanced Face Detection technology, Pet Detection
- Digital Video Format
- MPEG-4
- Image Recording Format
- JPEG
- 1280 x 720
- Interface
- USB 2.0
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO auto
- Exposure Metering
- Multi-segment, spot
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Landscape, portrait mode, beach/snow, self-portrait, fireworks, 3D image, panorama assist, night scene, sports mode, sunset, indoor, cuisine, candle, beauty, night scene with portrait, documents, underwater snapshot, dog, cat
- Special Effects
- Fisheye, soft focus, Water Colour, Drawing, Pop Art, pin hole, Punk, Sparkle
- White Balance
- Automatic, presets
- White Balance Presets
- Fluorescent, sunlight, tungsten light, overcast, Underwater
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 4 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 28 - 102mm
- Focus Adjustment
- Automatic
- 50 cm
- Macro Focus Range
- 2cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 8 groups / 10 elements
- Built-in lens shield, ED glass, aspherical lens
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- Effective Flash Range
- 0.2 m - 4.3 m: ISO 800
Additional Features
- Continuous Shooting Speed
- 0.6 frames per second, 3 frames per second (5MP)
- Self-Timer Delay
- 2sec, 12sec
- Additional Features
- Audio recording, RGB primary colour filter, digital noise reduction, digital image rotation, water resistant, shock resistant, histogram display, cropping an image, resizing an image, saturation control, in-camera red-eye fix, face detection, USB charging, dual image stabilization, Shadow Adjustment Technology, freezeproof, Advanced Face Detection Technology, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, Nitrogen-filled
Display
- 2.7" LCD display
- Display Format
- 230,000 pixels
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , HDMI output , Composite video/audio output
Software
- Software
- Drivers & Utilities, [ib] software
- Included Accessories
- Hand strap, AC power adaptor, USB cable, A/V cable
- Protection
- Waterproof, freezeproof, shockproof
- Underwater Use
- Underwater Depth
- Up to 3 m
- Battery Type
- Olympus LI-42B Lithium Ion
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Internal Storage
- 19.5 MB
- Image Storage
- JPEG 4288 x 3216 , JPEG 3264 x 2448 , JPEG 2560 x 1920 , JPEG 2048 x 1536 , JPEG 1600 x 1200 , JPEG 640 x 480 , JPEG 4288 x 2416 , JPEG 1920 x 1080
- Video Capture
- MPEG-4 - 1280 x 720 , MPEG-4 - 640 x 480 , MPEG-4 - 320 x 240
- 9.6 cm
- 2.3 cm
- 6.3 cm
- 155 g
- -10 °C
