The E-PL7 is a compact, interchangeable lens camera with a modern twist, built-in Wi-Fi and the upgraded OI.Share App let you control the camera remotely and post images instantly, while spectacular image quality, a selfie-centric touch screen interface and numerous creative tools make this the perfect choice for aspiring photographers.
Can such a small camera handle 15 different lenses? It can when it's the E-PL7. Build your system from an impressive assortment of M.Zuiko Micro Four Thirds fast primes, wide-angle and telephoto zooms, and macros, all with the unmatched digital-specific optics and premium build quality that set Olympus glass apart.
Genuine leather body jackets and lens covers. An add-on electronic viewfinder. A variety of external flashes. A compact underwater housing compatible with five M.Zuiko wide-angle and macro lenses. Add style and functionality to your E-PL7 with a wide array of premium accessories.
Sharp images ahead
The same advanced core image processing technology - 16MP live MOS CMOS sensor, TruePic VII image processor and in-body three-axis image stabilization - found in Olympus' critically acclaimed OM-D E-M10 lives inside the E-PL7. Every nuance of your subjects will be captured at a level of detail that will astound you. -
Fast and flexible
Life moves fast - but the E-PL7 is faster. Its lightning-quick autofocus system facilitates high-speed sequential shooting - up to 8 frames per second. The 81-point AF grid covers the entire frame so you can zero in on any area. Improved AF tracking makes panning on a moving subject easier than ever, and focus peaking improves your accuracy in manual focus mode. -
A smarter connection
Turn your smartphone into a photographic accessory with the E-PL7. Its built-in Wi-Fi allows you to control the camera remotely, which is great for selfies, tripod shooting and - to the E-PL7 - video recording. The camera's unique QR code lets you instantly connect your smart device and camera using the newly improved OI.Share App. -
License to create
The E-PL7's array of fun and inventive in-camera creative tools includes 14 art filters, 7 art effects, 5 photo story layouts and built-in HDR. Photo & movie capture lets you shoot full-res stills and HD video simultaneously, while the old film effect adds scratches and dust marks to give your videos a vintage look.
- Olympus PEN E-PL7 - digital camera M.Zuiko Digital 14-42mm lens
- Product Type
- Digital camera - 1080p - mirrorless system
- Lens Included
- M.Zuiko Digital 14-42mm lens
- Memory Card Slot
- SD card
- Image Processor
- TruePic VII
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 16.1 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 3x zoom - 14 - 42 mm - f/3.5-5.6 ED EZ
- Focus Adjustment
- Automatic
- Min Focus Distance
- 25 cm
- Image Stabiliser
- Optical (3-axis image sensor shift mechanism)
- Camera Flash
- Detachable flash
- External Flash Name
- Olympus FL-LM1
- Display
- LCD display - 3"
- Supported Battery
- Olympus BLS-50 Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 11.49 cm x 3.84 cm x 6.7 cm
- 357 g
- Product Type
- Lens Included
- Enclosure Colour
- Black
- Sensor Resolution
- 16.1 Megapixel
- Optical Sensor Type
- Live MOS
- Total Pixels
- 17,200,000 pixels
- Effective Sensor Resolution
- 16,100,000 pixels
- Optical Sensor Size
- Four Thirds (17.3 x 13.0 mm)
- ISO (Max)
- 25600
- Native ISO
- 100-1600
- Extended ISO (Max)
- 25600
- Sensor Dust Reduction
- Sensor Features
- Supersonic Wave Filter (SWF)
- Optical Zoom
- 3x
- Image Processor
- TruePic VII
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- HDR Mode
- HDR post-processing
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- Auto Focus Points (Zones) Qty
- 81
- AE/AF Control
- Face-priority AF, Subject-tracking AF, Touch Area AF, Eye detection AF
- Face Detection
- Eye Detect AF
- Digital Video Format
- AVI, MJPEG, H.264, MOV
- Image Recording Format
- JPEG, RAW, RAW + JPEG, MPO
- 1920 x 1080
- Interface
- Composite video/audio, HDMI, USB 2.0, Wireless LAN
Exposure & White Balance
- Light Sensitivity
- ISO 200-25600, ISO auto (200-25600)
- Exposure Metering
- Multi-segment, centre-weighted, spot, highlight spot, shadow spot
- Exposure Metering Zones
- 324
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, macro, beach/snow, landscape-portrait, Children, fireworks, 3D image, night scene, panning, sports mode, sunset, candle, high key, night scene with portrait, low key, documents, nature macro, e-portrait, auto-panorama, fisheye converter, wide converter, macro converter, handheld starlight
- Bracketing Modes
- Art Filter bracketing, focus bracketing, ISO sensitivity bracketing
- Special Effects
- Soft focus, Water Colour, Diorama, Cross Process, partial colour, Grainy Film, Light Tone, Pop Art, Pale & Light Colour, pin hole, Gentle Sepia, Dramatic Tone, Key Line, Vintage
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Sunlight, tungsten light, Flash, shade, overcast, Underwater, 2000K - 14000K
- Shutter Type
- Mechanical
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 60 sec
- Exposure Compensation
- ±3 EV range, in 1, 1/2 or 1/3 EV steps
- Auto Exposure Bracketing
- 7 steps in 1/3 or 2/3 EV steps
- White Balance Bracketing
- X-sync Speed
- 1/250sec, 1/4000 sec
- Exposure Range
- EV -2-20 - wide lens (ISO 100)
Lens System
- Zoom lens - 3x zoom - 14 - 42 mm - f/3.5-5.6 ED EZ - zoom
- Focal Length Equivalent to 35mm Camera
- 28 - 84mm
- Focus Adjustment
- Automatic
- 25 cm
- Max View Angle
- 75 degree(s)
- Zoom Adjustment
- Manual
- Lens Construction
- 8 groups / 9 elements
- Filter Size
- 40.5 mm
- Lens Mounting Type
- Micro Four Thirds
- ED glass, aspherical lens
Camera Flash
- Camera Flash
- Detachable flash
- Guide Number (m / ISO 100)
- 10
- Flash Modes
- Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation, wireless off-camera control
- Olympus FL-LM1
Additional Features
- Continuous Shooting Speed
- 8 frames per second, 3.7 frames per second
- Self-Timer Delay
- 2sec, 12sec
- Flash Terminal
- Hot shoe
- Additional Features
- Audio recording, built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, cropping an image, resizing an image, saturation control, in-camera red-eye fix, shadow point display, highlight point display, face detection, built-in help guide, Shadow Adjustment Technology, in-camera RAW processing, Full-time Live View, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, Touch Shutter technology, FlashAir Card Ready
Display
- 3" LCD display
- Display Format
- 1,037,000 pixels
- Display Form Factor
- Folding
- Touch Screen
- Display Features
- Display brightness control, display colour control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Wind noise reduction, sensitivity control
- Connector Type
- USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
Software
- Software
- Drivers & Utilities, Olympus Viewer 2
- Included Accessories
- Battery charger, dust cap, body cap, lens cap, shoulder strap, USB cable
- Body Material
- Metal
- Battery Type
- Olympus BLS-50 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 350 shots (Live View mode)
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Image Storage
- RAW 4608 x 3456 - 17 MB , JPEG 4608 x 3456 - 7.5 MB , JPEG 4608 x 3456 - 3.5 MB , JPEG 3200 x 2400 - 1.7 MB , JPEG 1280 x 960 - 0.4 MB
- Video Capture
- MOV - 1920 x 1080 - 30 fps - 24Mbps , MOV - 1920 x 1080 - 30 fps - 16Mbps , MOV - 1280 x 720 - 30 fps - 12Mbps , MOV - 1280 x 720 - 30 fps - 8Mbps , MJPEG - 1280 x 720 - 30 fps , MJPEG - 640 x 480 - 30 fps
- 11.49 cm
- 3.84 cm
- 6.7 cm
- 357 g
- 0 °C
- 40 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- 30 - 90%
- Humidity Range Storage
- 10 - 90%
