The ME-33 boundary microphone is the next generation of omni-directional sound capture equipment from Olympus. Combined with an Olympus professional voice recorder, the ME-33 is the ideal solution for recording meetings, conference calls and more in large rooms with many attendees. The ME-33 boundary microphone is purpose-built to clearly record voice at a distance. It automatically cuts extremely high- and low-frequency sounds, improving audio quality and recording usability.
Record from a distance
The ME-33 is a powerful, omni-directional microphone designed to record voices from a distance - even in the largest conference rooms. -
Superior sound quality
By automatically cutting extremely high- and low-frequency sounds, the ME-33 consistently produces clear, usable audio files. -
Scalable recording power
Connect multiple microphones to expand the ME-33's capabilities - up to six units for stereo recording and three units for monaural recording.
- Olympus ME-33 - microphone
- Product Type
- Microphone
- Microphone
- External
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Mono
- Product Type
- Microphone
- 12 cm
- Diameter
- 2.3 cm
- 110 g
Microphone
- Mono
- Connectivity Technology
- Wired
- Sensitivity
- -35 dB
- Frequency Response
- 70 - 10000 Hz
- Audio Input Details
- Omni-directional - 70 - 10000 Hz - Output Impedance 2.2 kOhm
- Connector Type
- Microphone (mini-phone mono 3.5 mm) , Audio line-in (mini-phone mono 3.5 mm)
- Cable Details
- Microphone cable - 2 m
