With the Olympus LS-3 you can have it all: superb sound quality, smooth operation and a durable, take-me-anywhere design concept that fits in literally every pocket. Its incredibly small size, you'll find many examples of advanced sound engineering: Awesome superior-to-CD quality sound due to the 24-bit/96 kHz PCM format, two directional microphones with 90° orientation for most natural stereo recording, plus an omni-directional center microphone capable of capturing lower bass ranges with stunning clarity. If it's a bit hectic you will love the pre-recording option, which enables you to start recording up to 2 seconds before you press the recording button. If that's still not enough, you can extend the recording capacity using the microSD card slot. Furthermore, the LS-3 comes with rechargeable Ni-MH batteries and an internal USB charging function ideal for people on the move. Whether you're a musician looking to record practice sessions, shows or song ideas, a nature enthusiast with a passion for capturing bird songs, a journalist, choir or theater director, or simply anyone who demands exceptionally clear, crisp sound, the pocket-sized LS-3 is must-have gear.
- Olympus LS-3 - voice recorder
- Product Type
- Voice recorder flash based
- Enclosure Colour
- Black
- 4 cm x 1.6 cm x 11.2 cm
- 90 g
- Playback Digital Standards
- WAV, WMA, PCM, MP3
- Display
- LCD monochrome - 1.69"
- Supported Flash Memory Cards
- microSDHC, microSD
- Internal Memory
- 4 GB
- Speakers
- 1 x speaker - built-in - 400 mW
- Microphone
- Microphone - built-in
- Interface
- USB 2.0
- Battery
- 2 x AAA type - rechargeable - Nickel Metal Hydride
- Product Type
- Voice recorder
- Digital Player Type
- Flash based
- USB Specification Version and Speeds
- USB 2.0
- Enclosure Colour
- Black
- Enclosure Material
- Aluminium
- Interface Supported
- USB 2.0
- Audio Formats
Audio System
- Internal Memory
- 4 GB
- Functions
- Digital player, digital voice recorder
- Hold button
Display
- LCD - monochrome
- Display Illumination
- Diagonal Size
- 1.69"
Speaker System
- Speakers
- 1 x speaker - built-in - 400 mW - 8 Ohm
- Driver Details
- Speaker: 1 - 0.79"
Digital Player (Recorder)
- Data Storage Capability
- Up to 200 messages / 5 folders
Microphone
- Connector Type
- Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm) , USB 2.0
- Included Accessories
- Hand strap, carrying case
- Software
- Olympus Sonority
- Battery
- Included Qty
- 2
- OS Required
- Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.4.11 - 10.6
- 4 cm
- 1.6 cm
- 11.2 cm
- 90 g
