Olympus LS-11 8Gb Digital Voice Record
LS11 Speakers
Quicklinx: 72HKWS00 Mfr#: N2283521
  • MP3
The Olympus LS-11 Linear PCM Recorder delivers an unbeatable combination of high-tech audio quality, portability and creative flexibility. This ensures that crisp and rich audio recordings can be captured anywhere from the office to the street, or from the dance floor to the lush soundscapes of the natural world. Convenience has been improved another notch, with the ability to capture each superior audio file at the touch of a button. Designed to complement mobile modern lifestyles, the LS-11 fits comfortably in the palm of the hand for maximum freedom and flexibility. Ideal for musicians, journalists, pod casters, and anybody needing high quality audio recording and playback capability on the fly, this pocket-sized studio captures it all in superb 24 bit/96 kHz quality. An editing feature even allows files to be edited in the device, while Auto Recording makes sure no important sound is lost by switching on automatically once a certain audio level has been reached.
  • A compact, lightweight powerhouse of audio recording
    Drawing on 40 years of experience, Olympus has put a feature-packed audio studio in one 5-ounce PCM recorder. The LS-11, with two high-sensitivity microphones and 8GB of internal memory, is the star of the show when it comes to capturing and playing back crystal clear audio, whether for personal enjoyment, hobbies, or even important business functions.
  • 24-bit/96kHz Linear PCM recording
    Every note played by the band, every word selected by the guest speaker, every bark and chirp heard in the local park, and every giggle from the kids in the backyard - the digital recording capabilities of the LS-11 help capture it all in rich, better-than-CD quality sound.
  • 8GB of memory, 23 hours of battery life
    When you combine its 8GB of memory with its ultra-long battery life (up to 23 hours), you immediately see how the LS-11 benefits those who demand hours upon hours of effortless, worry-free audio recording. An additional 32GB of memory can be added with an SD or SDHC card.
  • Multiple formats and features
    With the LS-11 you can do stereo or mono recording in WAV, MP3 or WMA formats, fine tune your recording with an LCD-displayed level meter, edit the audio files, or use an auto-record function that activates (and shuts off) the LS-11 at pre-set levels. Sounds good!
Olympus LS-11 - voice recorder
Voice recorder flash based
Enclosure Colour
Silver
4.8 cm x 2.2 cm x 13.2 cm
165 g
Playback Digital Standards
WAV, WMA, PCM, MP3
Display
LCD monochrome
Supported Flash Memory Cards
SDHC, SD Memory Card
Internal Memory
8 GB
Speakers
2 x main channel speaker - built-in - 200 mW
Microphone
Microphone - built-in
USB 2.0
2 x AA type
Voice recorder
Digital Player Type
Flash based
Digital Player Functions
Line-in recording
USB Specification Version and Speeds
USB 2.0
Enclosure Colour
Silver
Interface Supported
USB 2.0
Audio Formats
WAV, WMA, PCM, MP3
Audio System
Internal Memory
8 GB
Functions
Digital recorder, digital voice recorder
Display
LCD - monochrome
Speaker System
Speakers
2 x main channel speaker - built-in - 200 mW - 8 Ohm
Driver Details
1 - 0.63"
Digital Player (Recorder)
Sample Rate
4 kHz, 96 kHz, 48 kHz
Microphone
Connector Type
Microphone (mini-phone 3.5mm) , Headphones (mini-phone stereo 3.5 mm) , Audio line-in (mini-phone stereo 3.5 mm) , USB 2.0
Hand strap
Software
Steinberg Cubase LE4
Power adapter - external
2 x AA type
Included Qty
2
Battery Life Details
Digital recording - Alkaline - up to 23 hour(s)
Microsoft Windows 2000, Microsoft Windows XP, Apple MacOS X 10.2, Apple MacOS X 10.3, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.5
Additional Requirements
DVD-ROM
4.8 cm
2.2 cm
13.2 cm
165 g
