Olympus E-PM2 PEN Camera White/Silver 14-42mm, 40-150mm Lens Kit
Quicklinx: 8T6QWS00 Mfr#: V206022WE000
  • SDHC Memory Card
The Olympus PEN E-PM2 is all the proof you need that small and stylish can deliver impressive images. This compact technological wonder features an expansive 16-megapixel Live MOS sensor and TruePic VI image processor for powerfully vivid images that rival the quality of an SLR. Let the camera achieve photographic perfection with features like iAuto and 23 scene select modes. Or take control using direct live guide. Explore your creative side with 12 ready-to-use art filters. The PEN E-PM2 features technology to help you shoot brilliantly when light is hard to find.
  • 16-megapixel Live MOS image sensor
    Featuring the 16-megapixel Live MOS sensor of the OM-D E-M5, the Olympus micro four thirds flagship, the PEN E-PM2PM2, is optimized to maximize the performance of all mZuiko digital lenses in any shooting condition. Improvements to the sensitivity and read-out speed of the existing sensor makes shooting and Full HD movie recording possible.
  • TruePic VI image processor
    TruePic VI image processor, designed specifically for the Olympus PEN, features Real Color technology for improved color reproduction and color gradation. The faster processor also allows for a shorter recovery time between shots.
  • Proven dust reduction system
    Olympus's dust reduction system assures spot-free images, even if you change lenses. Every time you turn on the camera, the supersonic wave filter silently vibrates, flinging and collecting dust so that it doesn't interfere with the picture imaging at any time.
  • In-body image stabilization
    Say goodbye to blurry images. Olympus's in-body image stabilization technology makes it possible to use any micro four thirds lenses, from wide-angle to telephoto, for perfectly clear, crisp photos no matter what the shooting situation, even in low light!
  • Navigation on 3" LCD
    The E-PM2 features a vertical bar touch navigation menu. The E-PM2 is designed to optimize the touch screen LCD and was introduced to operate the MENU display with a simple operation instead of a mode dial. The E-PM2's touchscreen reacts quickly with the slightest touch and can focus by touch even if the subject is not in the center.
  • Live guide and direct live guide button
    The E-PM2's live guide system allows you to preview effects as you adjust them before the image is even captured. With a simple touch, slide through numerous photographic effects, such as brightness, color saturation, blur background, etc. It is even easier to get to the live guide menu at the touch of a button on the top of the camera.
  • iAuto
    A convenient, fully automated feature that detects the scene and applies the best of six situations just by aiming the camera toward the subject. Backlight adjustments are automatically applied for portrait and landscape modes.
  • Immediate response one-touch shutter and control
    The E-PM2's touchscreen reacts quickly with the slightest touch and can focus by touch even if the subject is not in the center. Touch screen display makes it easy to choose AF points, capture a picture, change camera settings, release the shutter or navigate controls, simply by touching the screen.
  • 8 fps sequential shooting
    With the E-PM2 you can take up to eight photos a second, allowing you to easily capture that perfect shot, especially when your subject is moving.
  • FAST AF with face and eye detect
    The FAST (Frequency Acceleration Sensor Technology) AF system is able to focus at an incredible speed and offers 35 separate focus points that are spread over nearly the entire sensor, which makes it possible for pin-point accurate focusing on small subjects wherever they appear in the frame.
Olympus PEN E-PM2 - FlashAir Kit - digital camera M.Zuiko Digital 14-42mm II and M.Zuiko Digital 40-150mm lenses
Digital camera - 1080p - mirrorless system
Lens Included
Memory Card Slot
SD card
Image Processor
TruePic VI
Sensor Resolution
16.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 14 - 42 mm - f/3.5-5.6 Micro Four Thirds
Lens System (2nd)
Telephoto zoom lens - 3.8x zoom - 40 - 150 mm - f/4.0-5.6 Micro Four Thirds
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Detachable flash
External Flash Name
Olympus FL-LM1
Display
LCD display - 3"
Supported Battery
Olympus BLS-5 Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
White
10.98 cm x 3.38 cm x 6.42 cm
223 g
Lens Included
Enclosure Colour
White
Sensor Resolution
16.1 Megapixel
Optical Sensor Type
Live MOS
Total Pixels
17,200,000 pixels
Effective Sensor Resolution
16,100,000 pixels
Optical Sensor Size
Four Thirds (17.3 x 13.0 mm)
Field of View Crop Factor
2
ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
Supersonic Wave Filter (SWF)
Optical Zoom
3x
Image Processor
TruePic VI
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
HDR Mode
HDR post-processing
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
35
AE/AF Control
Subject-tracking AF
Face Detection
Eye Detect AF
Digital Video Format
AVI, MJPEG, H.264, MOV
Image Recording Format
JPEG, RAW, RAW + JPEG, MPO
1920 x 1080
Exposure & White Balance
Light Sensitivity
ISO 200-25600, ISO auto (200-25600)
Exposure Metering
Multi-segment, centre-weighted, spot, highlight spot, shadow spot
Exposure Metering Zones
324
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, beach/snow, landscape-portrait, Children, fireworks, panorama assist, night scene, sports mode, Document, high key, night scene with portrait, low key, nature macro, e-portrait, fisheye converter, macro converter
Bracketing Modes
Art Filter bracketing, focus bracketing, ISO sensitivity bracketing
Special Effects
Monotone, Vivid, Custom Effect, soft focus, natural, Muted, portrait, Water Colour, Diorama, Cross Process, Grainy Film, Light Tone, Pop Art, Pale & Light Colour, pin hole, Gentle Sepia, i-Enhance, Dramatic Tone, Key Line, Monochrome Art
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight, Flash, shade, Underwater
Max Shutter Speed
1/4000 sec
Min Shutter Speed
2 sec
Exposure Compensation
±3 EV range, in 1, 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/250sec
Exposure Range
EV 0-20 (ISO 100)
Lens System
Focal Length Equivalent to 35mm Camera
28 - 84mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
75 degree(s)
Zoom Adjustment
Manual
Lens Construction
7 groups / 8 elements
Filter Size
37 mm
Lens Mounting Type
Micro Four Thirds
Aspherical lens, MSC technology
Lens System (2nd)
80 - 300mm
Min Focus Distance
90 cm
Focus Adjustment
Automatic, manual
Lens Construction
10 groups / 13 elements
Filter Size
58 mm
Internal focusing system, ED glass, MSC technology
Camera Flash
Camera Flash
Detachable flash
Guide Number (m / ISO 100)
7
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation, wireless off-camera control
External Flash Name
Olympus FL-LM1
Additional Features
Continuous Shooting Speed
8 frames per second, 3 frames per second, 3.6 frames per second
Self-Timer Delay
2sec, 12sec
Flash Terminal
Hot shoe
Additional Features
Audio recording, built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, cropping an image, resizing an image, saturation control, in-camera red-eye fix, shadow point display, highlight point display, face detection, built-in help guide, Shadow Adjustment Technology, in-camera RAW processing, Full-time Live View, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, Touch Shutter technology, FlashAir Card Ready
Display
3" LCD display
Display Format
460,000 pixels
Display Form Factor
Built-in
Touch Screen
Display Features
Display brightness control, display colour control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction, sensitivity control
Connector Type
USB 2.0 , Composite video/audio output , HDMI output , Accessory port , Remote control
Software
Software
Drivers & Utilities, Olympus Viewer 2
Battery charger, dust cap, body cap, lens cap, shoulder strap, USB cable, audio / video cable
Battery Type
Olympus BLS-5 Lithium Ion
Details
Battery Life Details
Photo shooting - 360 shots (IS on)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Memory Card
8 GB SDHC
Image Storage
RAW 4608 x 3456 - 17 MB , JPEG 4608 x 3456 - 7.5 MB , JPEG 4608 x 3456 - 3.5 MB , JPEG 2560 x 1920 - 1.1 MB , JPEG 1024 x 768 - 0.3 MB
Video Capture
H.264 - 1920 x 1080 - 30 fps - 20Mbps , H.264 - 1920 x 1080 - 30 fps - 17Mbps , H.264 - 1280 x 720 - 30 fps - 13Mbps , H.264 - 1280 x 720 - 30 fps - 10Mbps , MJPEG - 1280 x 720 - 30 fps , MJPEG - 640 x 480 - 30 fps
10.98 cm
3.38 cm
6.42 cm
223 g
30 - 90%
