Olympus DS-9000 Standard Edition (w/o cradle, AC-Adapter)
Quicklinx: DR7VWS00 Mfr#: V741020BE000
£284.96 ex VAT
£341.95 inc VAT
You decide when, where and how you dictate. Two microphones ensure flawless speech quality in every situation. Enjoy greater efficiency and more time for the things that are important to you.
  • Dictation mode for quiet environment
    No matter from which angle you speak into the device, the omni-directional microphones pick up your voice accurately. In this mode, you can hold the device in your hand any way you like.
  • Record conferences in stereo
    The two microphones into a 90° layout enable high quality recording in a realistic stereo feeling. You can then quickly and easily share the MP3 with others.
Olympus DS-9000 Standard Edition - voice recorder
Voice recorder flash based
Enclosure Colour
4.98 cm x 1.86 cm x 12.08 cm
116.5 g
Playback Digital Standards
PCM, MP3, DSSPro
Display
TFT - 240 x 320 - colour - 2.4"
Audio Specifications
Digital Recorder - response bandwidth: 200 - 7000 Hz
Supported Flash Memory Cards
SDHC, SD Memory Card
Internal Memory
2 GB
Speakers
1 x speaker - built-in - 320 mW
Microphone
Two microphones - built-in - omni-directional
Rechargeable - Lithium Ion - 1350 mAh
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
Enclosure Colour
Audio Formats
PCM, MP3, DSSPro
Audio System
Internal Memory
2 GB
File System Supported
2 GB
Functions
Digital voice recorder
Digital Recorder - response time: 200 - 7000 Hz
Microphone sensitivity selection, dual microphones, data encryption
Display
TFT - colour
Display Illumination
Display Illumination Colour
White
Resolution
240 x 320
Diagonal Size
2.4"
LED backlight
Speaker System
Speakers
1 x speaker - built-in - 320 mW - 8 Ohm
Driver Details
Speaker: 1 x full-range driver
Microphone
Microphone Operation Mode
Omni-directional
Connector Type
Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm) , Docking station , USB 2.0
Carrying Case
Case
Software
Olympus Dictation Management System R7
Included Qty
1
1350 mAh
4.98 cm
1.86 cm
12.08 cm
116.5 g
