Olympus DS-9000 Premium Kit
Quicklinx: DR7SWS00 Mfr#: V741020BE010
With advanced features including a superior noise canceling system, excellent file encryption, and supreme structural integrity, the DS-9000 will simplify your workflow and increase dictation management efficiency. Intelligent dual microphones control the directionality to keep the focus on the person dictating and suppress ambient noise in offices, hospitals, cars, airports and other noisy environments. A triple layer studio quality filter ensures accurate voice capture while reducing unwanted sounds such as breath and wind vibrations. This ensures superior accuracy that enhances workflow efficiency.
Encapsulated in a shockproof body and equipped with an optical slide switch, the DS-9000 is designed to be a strong, dependable workhorse in heavy use environments. Complete with 256-bit AES encryption and device pin lock, the DS-9000 provides trusted security to your most sensitive information.
Olympus DS-9000 - Premium Kit - voice recorder
Voice recorder flash based
Enclosure Colour
4.98 cm x 1.86 cm x 12.08 cm
116.5 g
Playback Digital Standards
PCM, MP3, DSSPro
Display
TFT - 240 x 320 - colour - 2.4"
Audio Specifications
Digital Recorder - response bandwidth: 200 - 7000 Hz
Supported Flash Memory Cards
SDHC, SD Memory Card
Internal Memory
2 GB
Speakers
1 x speaker - built-in - 320 mW
Microphone
Two microphones - built-in - omni-directional
Rechargeable - Lithium Ion - 1350 mAh
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
Enclosure Colour
Audio Formats
PCM, MP3, DSSPro
Audio System
Internal Memory
2 GB
File System Supported
2 GB
Functions
Digital voice recorder
Digital Recorder - response time: 200 - 7000 Hz
Microphone sensitivity selection, dual microphones, data encryption
Display
TFT - colour
Display Illumination
Display Illumination Colour
White
Resolution
240 x 320
Diagonal Size
2.4"
LED backlight
Speaker System
Speakers
1 x speaker - built-in - 320 mW - 8 Ohm
Driver Details
Speaker: 1 x full-range driver
Microphone
Microphone Operation Mode
Omni-directional
Connector Type
Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm) , Docking station , USB 2.0
Carrying Case
Case
Docking station, micro-USB cable
Software
Olympus Dictation Management System R7
Power adapter
Included Qty
1
1350 mAh
4.98 cm
1.86 cm
12.08 cm
116.5 g
