Olympus DS-5000iD Digital Dictation
Quicklinx: 5GB4WS00 Mfr#: N2275521
  • microSDHC
  • microSD
The DS-5000 is tailored to meet all professional dictation requirements and is part of the complete Olympus dictation solution comprising voice recorder, transcription kit and dictation management software. Regardless of the dictation situation, this first-class voice recorder has all bases covered in the entire process. Housed in a luxurious metal body that exudes elegance, it not only plays the part - it also looks the part.
Business users often discuss matters that are highly confidential - or at least not intended for everyone's ears. That's why the DS-5000 incorporates numerous security features to ensure files are protected from unauthorized playback or duplication. For starters, this model allows voice files to be encrypted and decrypted. Furthermore, users can set up password protection on their device. The special DS-5000iD model even enables protection using biometric information. In this way maximum security is assured.
While the DS-5000 is a veritable powerhouse, operation remains simple. Menu choices are intuitive to let the user focus on the business at hand. A single slide switch allows the most common functions to be accessed in just a fraction of a second. Further navigation buttons are located ergonomically in the center of the device to ensure easy data input and access to settings. Allowing all information to be seen at a glance in a choice of six languages, this model also features a large, back-lit LCD, which is protected against scratches thanks to a high-grade, coated screen.
A business tool is nothing if it is not dependable. That's why Olympus has gone to great lengths to ensure the DS-5000 performs exceptionally in this regard. Its metal body protects it against the knocks and bumps of daily use. The slide switch mechanism, which runs on rubber rollers for virtually noise-free operation, has been thoroughly tested for extended use. The USB connector and battery door have been specifically designed for heavy-duty treatment. And when it's time to take the recorder from the desktop cradle to the hand, users will enjoy the convenience of one-hand dock and undock functionality. Furthermore, due to extra-low battery consumption, the DS-5000 continues recording after others have long given up the ghost.
  • As flexible as you are
  • High security for peace of mind
  • Simplicity in action
  • A reliable companion at all times
Olympus DS-5000iD - voice recorder
Voice recorder flash based
11.3 cm x 1.7 cm x 5 cm
110 g
Playback Digital Standards
DSSPro
Sound Output Mode
Mono
Display
LCD
Audio Specifications
Digital Player - response bandwidth: 200 - 7000 Hz
Supported Flash Memory Cards
SDHC, microSDHC, microSD, SD Memory Card
Speakers
1 x speaker - built-in
Microphone
Microphone
USB 2.0
Rechargeable - Nickel Metal Hydride
Voice recorder
Digital Player Type
Flash based
Enclosure Material
Metal
Interface Supported
USB 2.0
Audio Formats
DSSPro
Audio System
File System Supported
2.5 GB
Sound Output Mode
Mono
Functions
Digital voice recorder
Digital Player - response time: 200 - 7000 Hz
Microphone sensitivity selection
Display
LCD
Display Illumination
Speaker System
Speakers
Driver Details
Speaker: 1 x full-range driver - 0.91"
Digital Player (Recorder)
Edit Functions
Track marking
Microphone
Microphone
Connector Type
Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm)
Carrying Case
Case - leather
Docking station, USB cable, SD Memory Card (2GB), microSD Card (512MB)
USB cable
Power adapter - external
Run Time (Up To)
28 hour(s)
Microsoft Windows XP Professional, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 2000 Professional SP4, Microsoft Windows XP Home Edition SP2, Microsoft Windows Vista Home Basic, Microsoft Windows Vista Business, Microsoft Windows Vista Home Premium, Microsoft Windows Vista Ultimate, Microsoft Windows Vista Enterprise, Microsoft Windows Server 2003 x64 Edition, Apple MacOS X 10.3.9 - 10.5
Additional Requirements
USB port
11.3 cm
1.7 cm
5 cm
110 g
Resources
The following resources are available for the Olympus DS-5000iD Digital Dictation
