Olympus DS-5000 Digital Dictation
Quicklinx: 5KD4WS00 Mfr#: N2274121
  • microSDHC
  • microSD
The DS-5000's intuitive controls and single slide switch simplify operation. The device has a large, backlit, easy-to-read LCD screen that reveals file information, recording time and events on the front of the recorder. Centralized navigation buttons enable easy data input and changes of settings. Users new to digital dictation as well as those on the leading edge will appreciate the DS-5000's sophisticated feature set that can be customized to provide a seamless dictation solution suitable to their work environment. It is built to meet the needs of an active professional with an extremely durable slide switch mechanism and robust buttons, USB connector and battery door.
The DS-5000 accepts SD/SDHC and microSD memory cards, providing users with media versatility. Three programmable buttons speedup reaction time. With no extraneous buttons, the DS-5000 allows users to program the functions they use the most onto three buttons for quick and effortless use.
Protecting the confidentiality and security of recordings is essential in the workplace. For this reason, the DS-5000 offers file encryption and device password protection. In addition to these features, the DS-5000D model also features a biometric fingerprint reader to secure the device from unauthorized access, thereby protecting confidential recordings.
  • Slide switch operation
    Quiet and easy to use slide switch results in high performance, comfort, and increased productivity.
  • Three programmable buttons
    It provides customized functions to suit your dictation needs. The recorder firmware can also be programmed for additional functionality and flexibility.
  • Memory and storage
    It supports SD and microSD, dual memory cards.
  • Device lock function with password
    Lock or password can protect your files to keep them safe and secure.
  • Multi-function cradle
    It recharges the Ni-MH battery pack, allows hands-free recording, and provides for fast and easy uploading/downloading of data to your PC.
Olympus DS-5000 - voice recorder
Voice recorder flash based
11.3 cm x 1.7 cm x 5 cm
110 g
Playback Digital Standards
DSSPro
Sound Output Mode
Mono
Display
LCD
Audio Specifications
Digital Player - response bandwidth: 200 - 7000 Hz
Supported Flash Memory Cards
SDHC, microSDHC, microSD, SD Memory Card
Speakers
1 x speaker - built-in
Microphone
Microphone
USB 2.0
Rechargeable - Nickel Metal Hydride
Voice recorder
Digital Player Type
Flash based
Enclosure Material
Metal
Interface Supported
USB 2.0
Audio Formats
DSSPro
Audio System
File System Supported
2.5 GB
Sound Output Mode
Mono
Functions
Digital voice recorder
Digital Player - response time: 200 - 7000 Hz
Microphone sensitivity selection
Display
LCD
Display Illumination
Speaker System
Speakers
Driver Details
Speaker: 1 x full-range driver - 0.91"
Digital Player (Recorder)
Edit Functions
Track marking
Microphone
Microphone
Connector Type
Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm)
Carrying Case
Case - leather
Docking station, USB cable, SD Memory Card (2GB), microSD Card (512MB)
USB cable
Power adapter - external
Run Time (Up To)
28 hour(s)
Microsoft Windows XP Professional, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 2000 Professional SP4, Microsoft Windows XP Home Edition SP2, Microsoft Windows Vista Home Basic, Microsoft Windows Vista Business, Microsoft Windows Vista Home Premium, Microsoft Windows Vista Ultimate, Microsoft Windows Vista Enterprise, Microsoft Windows Server 2003 x64 Edition, Apple MacOS X 10.3.9 - 10.5
Additional Requirements
USB port
11.3 cm
1.7 cm
5 cm
110 g
Resources
The following resources are available for the Olympus DS-5000 Digital Dictation
