Olympus DM-720 4GB Silver Digital Record & Transcribe Kit incAS-2400
Quicklinx: CWCSWS00 Mfr#: V414111SE040
  • microSD
  • microSDHC
The top of the class DM-720 includes high quality recording features packed into an efficient, smart metal body. It’s equipped with an easy-to-use interface, extended editing operations and various playback functions. The DM-720 provides outstanding practicality and reliability to support your recording needs.
  • Superb stereo-quality recording
    The DM-720 features a three microphone system that includes both directional and omni-directional microphones to faithfully capture the depth and fullness of the sounds recorded. The stereo microphones are arranged at a 90° angle to produce a natural stereo experience, with an added central microphone to compensate for low-range sounds. This Tresmic combination provides a wide frequency range for the most demanding professionals.
  • Hear every voice
    The Voice Playback function allows you to skip non-voice audio during playback, and only play the parts of the file where there is vocal content. Olympus' Voice Playback saves time and improves efficiency during transcription.
  • Intelligent recording
    With previous models, it was necessary to adjust the microphone sensitivity according to the recording environment, such as the number of people or the size of the meeting space. The Intelligent Auto Mode function makes it easier for users by automatically adjusting the microphone sensitivity according to the volume of the speaker. To set this function, select Auto for the recording level from the menu.
  • Capture every word
    Transcription mode is convenient when creating minutes from your recordings. While transcribing, users frequently repeat play, and stop to check the content. In Transcription Mode, the recorder will automatically playback the 3 seconds before the stop, so you can check the contents before proceeding. On the other hand, fast forward is preset to 3.5x so you can conveniently skip the silences in your recording.
  • Connect, save, share
    The DM-720 can connect directly to your PC via the built-in USB connector. This makes it possible to save data anytime, anywhere. Not only can you save and share data, but the DM-720 can also be charged via USB. All operations of recording, saving, sharing, and charging can be performed on this single, smart and easy-to-use voice recorder.
Olympus DM-720 - voice recorder
Voice recorder flash based
Bundled with
Olympus AS-2400 Transcription Kit
Enclosure Colour
Silver
10.59 cm x 1.44 cm x 3.96 cm
72 g
Playback Digital Standards
PCM, MP3
Sound Output Mode
Stereo
Digital Recording Time
5.5 hours - PCM recording, 24.5 hours - MP3 recording - 320 kbps, 61 hours - MP3 recording - 128 kbps, 123 hours - MP3 recording (mono) - 64 kbps, 985 hours - MP3 recording (mono) - 8 kbps
Display
LCD
Supported Flash Memory Cards
microSDHC, microSD
Internal Memory
4 GB
Speakers
1 x speaker - built-in
Microphone
Stereo microphone - built-in - stereo
1 x AAA type - rechargeable - Nickel Metal Hydride
Voice recorder
Digital Player Type
Flash based
Bundled with
Enclosure Colour
Silver
Audio Formats
PCM, MP3
Audio System
microSDHC, microSD
Internal Memory
4 GB
File System Supported
4 GB
Sound Output Mode
Stereo
Functions
Digital player, digital voice recorder
Playback speed control, noise cancelling circuit, voice activated, Voice Guidance
Display
LCD
Speaker System
Speakers
Driver Details
Speaker: 1 x full-range driver
Digital Player (Recorder)
Recording Time
Supported Bit Rate
8 - 320Kbps
Noise Cancelling
Variable Control Voice Actuator, calendar search, zoom recording
Microphone
Microphone Operation Mode
Stereo
Connector Type
Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm) , USB
Belt clip/viewing stand
Included Qty
1
Battery Life Details
Digital recording - up to 52 hours , Digital playback - up to 35 hours
10.59 cm
1.44 cm
3.96 cm
72 g
