The ML3320eco printer is suited to high speed, high volume data and word processing applications, where fast throughput and flexible paper management are required. This 9-pin, impact printer is engineered to be tough enough for dedicated printing in the most demanding environments. With outstanding reliability, ease-of-use and barcoding facilities as well as the ability to run twice as long as most printers in their class, they are ideal for customer service points in wholesale and service environments.
The ML3320eco can accommodate multipart forms and stock that are up to twice as thick as those that fit OKI's nearest competitor. Their relentless performance comes from OKI's unique, high durability printhead design; and a light, strong, efficient motor. The long-last rack-and-pinion drive system and a protective, impact-resistance chassis, make it resilient even in the toughest environments. With a patented optical sensor that places the printhead for precise output, and the auto-tear feature that accurately positions your continuous forms for a clean tear, right at the perforation - eliminating wasted forms and facilitating your day-to-day forms printing.
The ML3320eco has been developed to be eco-friendly. With power consumption at just 1.5W in sleep mode, your running costs and energy consumption are kept to a minimum, as well as reducing your carbon footprint.
High speed, high volume, outstanding reliability
The ML3320eco printer is suited to high speed, high volume data and word processing applications, where fast throughput and flexible paper management are required. -
Precision, flexibility and resilience
The ML3320eco can accommodate multipart forms and stock that are up to twice as thick as those that fit OKI's nearest competitor. Their relentless performance comes from OKI's unique, high durability printhead design; and a light, strong, efficient motor. The long-last rack-and-pinion drive system and a protective, impact-resistance chassis, make it resilient even in the toughest environments. -
Eco-friendly and cost effective
- OKI Microline 3320eco - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - B/W
- 5.8 kg
- Max Media Size
- Continuous paper 76 mm - 254 mm (width)
- Min Media Size (Custom)
- 76 mm
- Max Media Size (Custom)
- 254 mm
- Print Speed
- Up to 435 char/sec - max speed , Up to 387 char/sec - fast draft , Up to 387 char/sec - fast draft , Up to 290 char/sec - normal , Up to 290 char/sec - normal , Up to 73 char/sec - near letter , Up to 73 char/sec - near letter
- Max Resolution (B&W)
- 240 x 216 dpi
- Interface
- Parallel, USB 2.0
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON FX, Okidata Microline, IBM ProPrinter
- Barcodes
- OCR-B
- Media Type
- Envelopes, plain paper, continuous forms
- 3-year warranty with product registration
- 39.8 cm x 34.5 cm x 11.6 cm
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 435 char/sec - max speed - 12 cpi , Up to 387 char/sec - fast draft - 12 cpi , Up to 387 char/sec - fast draft - 10 cpi , Up to 290 char/sec - normal - 12 cpi , Up to 290 char/sec - normal - 10 cpi , Up to 73 char/sec - near letter - 12 cpi , Up to 73 char/sec - near letter - 10 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB 2.0
- 240 x 216 dpi
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
- OCR-B
RAM
- 128 KB
Media Handling
- Media Path Type
- Curved
- Media Type
- Max Media Size
- 76 mm
- 254 mm
- Media Sizes
- Envelope Sizes
- US No 6 (92 x 165 mm)
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76 mm - 254 mm (width)
- Max Sheets in Multi-Part Form
- 5
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
- MTBF
- 10,000 hour(s)
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 27.5 watt
- Power Consumption Sleep
- 1.5 watt
- Limited warranty - 3 years
- Sound Emission (Operating)
- 57 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 39.8 cm
- 34.5 cm
- 11.6 cm
- 5.8 kg
