OKI Microline 6300 FB-SC Mono Dot-Matrix Printer
Quicklinx: 7255WS00 Mfr#: 01265001
With print speeds of up to 450 characters per second and multi-part copy capability, the ML6300FB provides unerring support for businesses that have a strong customer service/productivity emphasis. Its flat bed design and straight paper-path makes it ideal for printing on awkward media varying from light to heavy, including card stock.
Businesses most likely to benefit from the ML6300FB include hotels, banks, retail stores, or remote and even industrial offices that frequently deal with pre-printed forms, checks, tickets, receipts and labels - both pre-cut and tractor fed. Additionally, the small footprint makes it the ideal choice for businesses where space is at a premium.
OKI Microline 6300 FB-SC - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
7.5 kg
Max Media Size
Continuous paper 76.2 mm - 304.8 mm (width)
Max Media Size (Custom)
304.8 mm
Print Speed
Up to 450 char/sec , Up to 400 char/sec - fast draft , Up to 300 char/sec - normal , Up to 100 char/sec
Max Resolution (B&W)
360 dpi
Parallel, USB
RAM Installed (Max)
64 KB
Language Simulation
IBM AGM, EPSON LQ, IBM ProPrinter
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet, OCR-A, OCR-B
Media Type
Continuous forms, tickets
Microsoft Certification
Compatible with Windows 7
3-year warranty with product registration
42.5 cm x 25.5 cm x 21 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 450 char/sec , Up to 400 char/sec - fast draft - 10 cpi , Up to 300 char/sec - normal - 10 cpi , Up to 100 char/sec - 10 cpi
Wired
Parallel, USB
360 dpi
Language Simulation
Fonts Included
1 x barcode
Barcodes
RAM
RAM Installed (Max)
64 KB
Media Handling
Media Type
Max Media Size
304.8 mm
Media Sizes
Media Thickness Range
Up to 0.36 mm
Media Weight
52 g/m² - 209 g/m²
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 304.8 mm (width)
1 x USB - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics
Consumables Included
1 x ribbon - up to 4 million characters , 1 x printhead - up to 200 million characters
MTBF
12,000 hour(s)
Power supply - internal
Frequency Required
50/60 Hz
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
58 dBA
42.5 cm
25.5 cm
21 cm
7.5 kg
7255 OKI High Quality Black Ribbon for ML6300 In Stock £17.37
