The wide carriage ML5791 is ideal where fast printing, reliability, versatile paper handling and superior quality text is essential. Whether you are printing invoices, purchase orders, spreadsheets, picking lists, call log slips, tickets, receipts or multi-part documents, the ML5791 keeps transactions smooth and your customers happy.
The ML5791 has been developed with eco-friendly technology. With power consumption of just 1.5 w in sleep mode, your running costs and energy consumption are kept to a minimum, as well as reducing your carbon footprint.
More paper paths give you flexibility. The three tractor feeding paths handle multi-part forms and continuous paper from either the front, rear or bottom. The two friction feeding paths handle cut-sheets, cards and envelopes from either the front or top.
A selection of pull and push tractors allow permanent stationary loading, for use on demand and handle multi-part and continuous forms more efficiently.
- OKI Microline 5791eco - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - B/W
- 10 kg
- Max Media Size
- Continuous paper 76.2 mm - 406.4 mm (width)
- Min Media Size (Custom)
- 76.2 mm x 76.2 mm
- Max Media Size (Custom)
- 406.4 mm x 558.8 mm
- Print Speed
- Up to 576 char/sec - high speed draft , Up to 480 char/sec - high speed draft , Up to 540 char/sec - draft , Up to 432 char/sec - draft , Up to 240 char/sec - letter , Up to 206 char/sec - letter , Up to 180 char/sec - letter , Up to 144 char/sec - letter , Up to 120 char/sec - letter , Up to 360 char/sec - draft , Up to 360 char/sec - draft , Up to 309 char/sec - draft
- Max Resolution (B&W)
- 360 dpi
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON ESC/P 2, IBM AGM, IBM PPR, EPSON LQ
- Barcodes
- Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, labels, plain paper, continuous forms, cards
- Power
- AC 230V
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 3-year warranty with product registration
- 59.2 cm x 37.5 cm x 19.1 cm
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
- Print Speed
- Up to 576 char/sec - high speed draft - 12 cpi , Up to 480 char/sec - high speed draft - 10 cpi , Up to 540 char/sec - draft - 15 cpi , Up to 432 char/sec - draft - 12 cpi , Up to 240 char/sec - letter - 20 cpi , Up to 206 char/sec - letter - 17.1 cpi , Up to 180 char/sec - letter - 15 cpi , Up to 144 char/sec - letter - 12 cpi , Up to 120 char/sec - letter - 10 cpi , Up to 360 char/sec - draft - 10 cpi , Up to 360 char/sec - draft - 20 cpi , Up to 309 char/sec - draft - 17.1 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 360 dpi
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 76.2 mm x 76.2 mm
- Media Sizes
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76.2 mm - 406.4 mm (width)
- Max Sheets in Multi-Part Form
- 6
- Connections
- 1 x parallel , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x printhead - up to 400 million characters , 1 x ribbon - up to 13 million characters
- MTBF
- 25,000 hour(s)
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 52 Watt
- Power Consumption Stand by / Sleep
- 1.5 Watt
- Software Included
- OKI LPR, OKI Status Monitor, OKI Network Set Up
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 57 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 59.2 cm
- 37.5 cm
- 19.1 cm
- 10 kg
