OKI Microline 5721eco Mono Dot-Matrix Printer
Quicklinx: 7QPPWS00 Mfr#: 01268501
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Dot-matrix
£514.87 ex VAT
£617.84 inc VAT
The 136 column ML5721eco dot matrix printer delivers fast, reliable multi-part forms printing and low running costs. A high 700cps (characters per second) print speed, fast throughput and ability to manage heavy medias make it perfect for demanding environments such as vehicle repair/service centers, warehouses, factories, wholesalers and freight forwarders.
Ideal for high duty applications, printing receipts, invoices, picking lists, reports and wide format spreadsheets, on single or multi-part paper, the ML5721eco printer will keep productivity levels high. And with multiple emulations built-in, replacing old printers is simple and straightforward.
  • Fast, reliable printing for demanding environments
    The ML5721eco dot matrix printer delivers fast, reliable multi-part forms printing and low running costs. Their high 700cps (characters per second) print speeds, fast throughput and ability to manage heavy medias make them perfect for demanding environments such as vehicle repair/service centers, warehouses, factories, wholesalers and freight forwarders.
  • Truly versatile paper handling
    The ML5721eco printer can feed both cut sheet paper and continuous forms with ease. Front, top, bottom and rear paper input paths and an on-board tractor feed unit that can be front or rear mounted provide truly versatile paper handling. A long life 9-pin print head delivers high quality documents on single or multi-part paper, printing up to 7 copies simultaneously.
  • Eco-friendly and cost effective
    Equipped with long life ribbons and a power saving 1.5W "sleep mode" the ML5721eco printer will keep running costs and energy consumption to the minimum, as well as reducing your carbon footprint.
OKI Microline 5721eco - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - B/W
10 kg
Max Media Size
Continuous paper 76.2 mm - 406.4 mm (width)
Min Media Size (Custom)
76.2 mm x 76.2 mm
Max Media Size (Custom)
406.4 mm x 558.8 mm
Print Speed
Up to 700 char/sec - super speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 431 char/sec - draft , Up to 113 char/sec - near letter , Up to 113 char/sec - near letter , Up to 113 char/sec - near letter , Up to 108 char/sec - near letter , Up to 108 char/sec - near letter
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON FX, IBM PPR, Okidata Microline
Barcodes
Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-B, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, continuous forms, cards, fanfold paper
AC 230V
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
3-year warranty with product registration
59.2 cm x 37.5 cm x 19.1 cm
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
Print Speed
Up to 700 char/sec - super speed draft - 12 cpi , Up to 600 char/sec - high speed draft - 10 cpi , Up to 600 char/sec - high speed draft - 12 cpi , Up to 600 char/sec - high speed draft - 15 cpi , Up to 600 char/sec - high speed draft - 17.1 cpi , Up to 600 char/sec - high speed draft - 20 cpi , Up to 450 char/sec - draft - 10 cpi , Up to 450 char/sec - draft - 12 cpi , Up to 450 char/sec - draft - 15 cpi , Up to 450 char/sec - draft - 20 cpi , Up to 431 char/sec - draft - 17.1 cpi , Up to 113 char/sec - near letter - 10 cpi , Up to 113 char/sec - near letter - 12 cpi , Up to 113 char/sec - near letter - 15 cpi , Up to 108 char/sec - near letter - 17.1 cpi , Up to 108 char/sec - near letter - 20 cpi
Wired
Parallel, USB
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
76.2 mm x 76.2 mm
406.4 mm x 558.8 mm
Media Sizes
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 406.4 mm (width)
Max Sheets in Multi-Part Form
7
1 x parallel , 1 x USB - 4 pin USB Type B
Consumables Included
1 x printhead - up to 400 million characters , 1 x ribbon - up to 13 million characters
MTBF
25,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
52 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Software Included
OKI LPR, OKI Status Monitor, OKI Network Set Up
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
57 dBA
Sound Emission (Quiet Mode)
52 dBA
59.2 cm
37.5 cm
19.1 cm
10 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Continuous paper 76.2 mm - 406.4 mm (width)
Brand: OKI
Price Range Ex VAT: £500 - £750
