The ML5720eco dot matrix printer delivers fast, reliable multi-part forms printing and low running costs. Its high 700cps (characters per second) print speeds, fast throughput and ability to manage heavy medias make it perfect for demanding environments such as vehicle repair/service centers, warehouses, factories, wholesalers and freight forwarders. Ideal for high duty applications, printing receipts, invoices, picking lists, reports or spreadsheets, on single or multi-part paper, the ML5720 printer will keep productivity levels high.
Fast, reliable printing for demanding environments
The ML5720eco dot matrix printer delivers fast, reliable multi-part forms printing and low running costs. Its high print speeds, fast throughput and ability to manage heavy medias make it perfect for demanding environments such as vehicle repair/service centers, warehouses, factories, wholesalers and freight forwarders. Ideal for high duty applications, printing receipts, invoices, picking lists, reports or spreadsheets, on single or multi-part paper, the ML5720eco printer will keep productivity levels high. -
Truly versatile paper handling
The ML5720eco printer can feed both cut sheet paper and continuous forms with ease. Front, top, bottom and rear paper input paths and an on-board tractor feed unit that can be front or rear mounted provide truly versatile paper handling. A long life 9-pin print head delivers high quality documents on single or multi-part paper, printing up to 7 copies simultaneously. -
Eco-friendly and cost effective
Equipped with long life ribbons and a power saving "Sleep mode", the ML5720 printer will keep running costs and energy consumption to the minimum, as well as reducing your carbon footprint.
- OKI Microline 5720eco - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - B/W
- 7.5 kg
- Max Media Size
- Continuous paper 76.2 mm - 254 mm (width)
- Min Media Size (Custom)
- 76.2 mm x 76.2 mm
- Max Media Size (Custom)
- 254 mm x 558.8 mm
- Print Speed
- Up to 700 char/sec - super speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 431 char/sec - draft , Up to 113 char/sec - near letter , Up to 113 char/sec - near letter , Up to 113 char/sec - near letter , Up to 108 char/sec - near letter , Up to 108 char/sec - near letter
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON FX, IBM PPR, Okidata Microline
- Barcodes
- Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, labels, plain paper, continuous forms, cards, fanfold paper
- Power
- AC 230V
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty with product registration
- 43.8 cm x 37.5 cm x 19.1 cm
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 700 char/sec - super speed draft - 12 cpi , Up to 600 char/sec - high speed draft - 10 cpi , Up to 600 char/sec - high speed draft - 12 cpi , Up to 600 char/sec - high speed draft - 15 cpi , Up to 600 char/sec - high speed draft - 17.1 cpi , Up to 600 char/sec - high speed draft - 20 cpi , Up to 450 char/sec - draft - 10 cpi , Up to 450 char/sec - draft - 12 cpi , Up to 450 char/sec - draft - 15 cpi , Up to 450 char/sec - draft - 20 cpi , Up to 431 char/sec - draft - 17.1 cpi , Up to 113 char/sec - near letter - 10 cpi , Up to 113 char/sec - near letter - 12 cpi , Up to 113 char/sec - near letter - 15 cpi , Up to 108 char/sec - near letter - 17.1 cpi , Up to 108 char/sec - near letter - 20 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 76.2 mm x 76.2 mm
- 254 mm x 558.8 mm
- Media Sizes
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width)
- Max Sheets in Multi-Part Form
- 7
- Connections
- 1 x parallel , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x printhead - up to 400 million characters , 1 x ribbon - up to 8 million characters
- MTBF
- 25,000 hour(s)
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 52 Watt
- Power Consumption Stand by / Sleep
- 1.5 Watt
- Software Included
- OKI LPR, OKI Status Monitor, OKI Network Set Up
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 57 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 43.8 cm
- 37.5 cm
- 19.1 cm
- 7.5 kg
