OKI Microline 5591eco Mono Dot-Matrix Printer
Quicklinx: 7JXVWS00 Mfr#: 01308902
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Dot-matrix
£499.40 ex VAT
£599.28 inc VAT
The Microline 5591 has been designed for use in the harshest of operating environments whilst offering the highest levels of flexibility and performance with unparalleled reliability.
OKI Microline 5591eco - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
7.8 kg
Max Media Size
Continuous paper 76.2 mm - 406.4 mm (width)
Min Media Size (Custom)
76.2 mm
Max Media Size (Custom)
406 mm
Print Speed
Up to 473 char/sec - max speed , Up to 420 char/sec - high speed draft , Up to 378 char/sec - utility , Up to 315 char/sec - utility , Up to 105 char/sec - letter , Up to 126 char/sec - letter
Max Resolution (B&W)
360 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P 2, IBM AGM, EPSON LQ, IBM ProPrinter
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, continuous forms
AC 230V
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
3-year warranty with product registration
55.2 cm x 34.5 cm x 12 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 473 char/sec - max speed - 15 cpi , Up to 420 char/sec - high speed draft - 10 cpi , Up to 378 char/sec - utility - 12 cpi , Up to 315 char/sec - utility - 10 cpi , Up to 105 char/sec - letter - 10 cpi , Up to 126 char/sec - letter - 12 cpi
Wired
Parallel, USB
360 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Path Type
Curved
Media Type
Max Media Size
76.2 mm
406 mm
Media Sizes
Envelope Sizes
Com-10 (105 x 241 mm)
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 406.4 mm (width)
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
Consumables Included
1 x printhead - up to 200 million characters , 1 x ribbon - up to 4 million characters
MTBF
20,000 hour(s)
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
45.9 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
56 dBA
Sound Emission (Quiet Mode)
52 dBA
55.2 cm
34.5 cm
12 cm
7.8 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Continuous paper 76.2 mm - 406.4 mm (width)
Brand: OKI
