The Microline 5521 has been designed for use in the harshest of operating environments whilst offering the highest levels of flexibility and performance with unparalleled reliability.
- OKI Microline 5521eco - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - B/W
- 7.7 kg
- Max Media Size
- Continuous paper 76 mm - 406 mm (width)
- Min Media Size (Custom)
- 76 mm
- Max Media Size (Custom)
- 406 mm
- Print Speed
- Up to 570 char/sec - super speed draft , Up to 507 char/sec - high speed draft , Up to 380 char/sec - utility , Up to 95 char/sec - near letter
- Max Resolution (B&W)
- 240 x 216 dpi
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON FX, Okidata Microline, IBM ProPrinter
- Barcodes
- OCR-B
- Media Type
- Envelopes, plain paper, continuous forms
- Power
- AC 230V
- 3-year warranty with product registration
- 55.2 cm x 34.5 cm x 12 cm
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 570 char/sec - super speed draft - 12 cpi , Up to 507 char/sec - high speed draft - 10 cpi , Up to 380 char/sec - utility , Up to 95 char/sec - near letter
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 240 x 216 dpi
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
- OCR-B
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 76 mm
- 406 mm
- Media Sizes
- Envelope Sizes
- Com-10 (105 x 241 mm)
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76 mm - 406 mm (width)
- Max Sheets in Multi-Part Form
- 6
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x printhead - up to 200 million characters , 1 x ribbon - up to 4 million characters
- MTBF
- 20,000 hour(s)
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 40.2 Watt
- Power Consumption Stand by / Sleep
- 1.5 Watt
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 56 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 55.2 cm
- 34.5 cm
- 12 cm
- 7.7 kg
