The fastest and highest quality printer in OKI's 24-pin dot-matrix range, especially recommended for high volume data processing requirements and quality high volume word processing tasks. The ML395 is excellent for reports and presentations.
Enhanced connectivity
Equipped with both parallel and serial interfaces, this printer offers versatile connectivity options, making it easy to integrate into any PC setup. -
High-speed printing
Achieve productivity with a printing speed of up to 607 char/sec, ensuring quick and efficient document handling for all your printing needs. -
Versatile media handling
Supports a wide range of media types including continuous forms, envelopes, and plain paper, catering to diverse printing requirements. -
Crisp monochrome output
With a resolution of 360 DPI, the OKI Microline 395B delivers clear and sharp monochrome prints, suitable for a variety of documents. -
Durable design
Featuring a robust dot-matrix printing technology and a 24 pin printhead, this printer is designed for long-lasting performance and reliability.
- OKI Microline 395B - printer - B/W - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 24 pin - B/W
- Form Factor
- Desktop
- 17 kg
- Max Media Size (Custom)
- 406 mm
- Print Speed
- Up to 607 char/sec - max speed , Up to 162 char/sec - letter , Up to 486 char/sec - draft
- Max Resolution (B&W)
- 360 dpi
- Interface
- Parallel, serial
- RAM Installed (Max)
- 23 KB (40 KB) integrated
- Language Simulation
- IBM X24E, IBM PPR, EPSON LQ
- Media Type
- Envelopes, plain paper, continuous forms, business cards
- Enclosure Colour
- White
- 3-year warranty
- 57 cm x 41.7 cm x 18 cm
- Printer Type
- Personal printer - dot-matrix - 24 pin - monochrome
- Form Factor
- Desktop
- Enclosure Colour
- White
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Parallel, serial
- 360 dpi
- PostScript Support
- Not available
- Fonts Included
- 7 x barcode , 6 x bitmapped
RAM
- 23 KB / 40 KB (max)
- Technology / Form Factor
- Integrated
Media Handling
- Media Path Type
- Curved, straight
- Media Type
- 406 mm
- Media Sizes
- A3 (297 x 420 mm)
- Media Feeders
- 3 x manual
- Max Sheets in Multi-Part Form
- 4
Duty Cycle
- Cartridge / Printhead Duty Cycle
- 200 million characters
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel - 36 PIN Centronics
- Power Device
- Power supply - integrated
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- 57 cm
- 41.7 cm
- 18 cm
- 17 kg
OKI ML-395 Black Ribbon | In Stock | £40.20 |
