OKI Microline 3410 Mono Dot-Matrix Printer
Quicklinx: 7QPHWS00 Mfr#: 09000269
The Microline 3410 is a powerful workhorse that has been designed to handle the most data intensive applications with an extremely high print speed coupled with superior copy capability. Main areas of use are high-volume forms applications such as listings, logistics documents, labels, heavy continuous forms etc. Equally at home in offices, warehouses or industrial production environments this printer can withstand extremes in operating conditions. The Microline 3410 comes with an in-built pushtractor with paper-park function. Available options include bottom power-tractor, mechanical pull-tractor and cut-sheet feeders.
OKI Microline 3410 - printer - B/W - dot-matrix
Printer Type
Personal printer - dot-matrix - 9 pin - B/W
Desktop
25.4 kg
Max Media Size
Roll (40.6 cm)
Max Media Size (Custom)
406 mm
Print Speed
Up to 104 char/sec - near letter , Up to 550 char/sec - max speed , Up to 417 char/sec - normal
Max Resolution (B&W)
240 x 216 dpi
Parallel, serial
RAM Installed (Max)
28 KB
Language Simulation
EPSON FX, IBM PPR
Media Type
Envelopes, labels, plain paper, continuous forms
AC 230V
Enclosure Colour
White
57 cm x 41.7 cm x 18 cm
Printer Type
Personal printer - dot-matrix - 9 pin - monochrome
Desktop
Enclosure Colour
White
Printer
Print Speed
Up to 104 char/sec - near letter - 10 cpi , Up to 550 char/sec - max speed - 10 cpi , Up to 417 char/sec - normal - 10 cpi
Wired
Parallel, serial
240 x 216 dpi
PostScript Support
Not available
Language Simulation
EPSON FX, IBM PPR
RAM
RAM Installed (Max)
28 KB
Media Handling
Media Path Type
Curved
Media Type
Max Media Size
Roll (40.6 cm)
406 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), Super A3/B (330 x 483 mm), A3 plus (329 x 423 mm), 364 x 356 mm, Tabloid Extra (305 x 457 mm)
Media Feeders
1 x manual
Max Sheets in Multi-Part Form
8
Duty Cycle
Cartridge / Printhead Duty Cycle
200 million characters
Cartridge / Printhead Included Qty
1
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel - 36 PIN Centronics
MTBF
8,000 hour(s)
Power supply - integrated
AC 230V ± 10%
Frequency Required
50/60 Hz
220 Watt
Software Included
Drivers & Utilities
5 °C
20 - 80%
Sound Emission
55 dB
57 cm
41.7 cm
18 cm
25.4 kg
7QPH OKI ML-3410 Single Black Ribbon In Stock £45.11
