The Microline 3390 narrow and wide carriage printer is designed for users who require excellent quality and flexibility from a single printer. The Microline 3390 is ideal for volume applications requiring high throughput and flexible changing between various print media. High reliability, ease of use and various in-built barcodes makes this printer the ideal tool for industrial, commercial, service, small business and office environments.
- OKI Microline 3390eco - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - B/W
- 5.8 kg
- Max Media Size
- Continuous paper 76.2 mm - 254 mm (width)
- Min Media Size (Custom)
- 76.2 mm
- Max Media Size (Custom)
- 254 mm
- Print Speed
- Up to 390 char/sec - max speed , Up to 260 char/sec - utility , Up to 312 char/sec - utility , Up to 104 char/sec - letter , Up to 87 char/sec - letter
- Max Resolution (B&W)
- 360 dpi
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- IBM AGM, EPSON LQ, IBM ProPrinter
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, labels, plain paper, continuous forms, cards
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 3-year warranty with product registration
- 39.8 cm x 34.5 cm x 11.6 cm
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
- Print Speed
- Up to 390 char/sec - max speed , Up to 260 char/sec - utility - 10 cpi , Up to 312 char/sec - utility - 12 cpi , Up to 104 char/sec - letter - 12 cpi , Up to 87 char/sec - letter - 10 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 360 dpi
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 76.2 mm
- 254 mm
- Media Sizes
- Envelope Sizes
- US No 6 (92 x 165 mm)
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width)
- Max Sheets in Multi-Part Form
- 5
- Connections
- 1 x parallel - 36 PIN Centronics ¦ 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x printhead - up to 200 million characters , 1 x ribbon - up to 2 million characters
- MTBF
- 10,000 hour(s)
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 30.4 Watt
- Power Consumption Stand by / Sleep
- 1.5 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 57 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 39.8 cm
- 34.5 cm
- 11.6 cm
- 5.8 kg
