The Microline 320 wide carriage printers are suited to high speed, high volume data and word processing applications, where speed is more important than letter quality. Reliability, ease of use and fast throughput make them ideal for customer service points in wholesale, retail and service environments: multi-part forms, labels, listings, customer service points, accounts and spreadsheets.
- OKI Microline 320 - printer - B/W - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 9 pin - B/W
- Form Factor
- Desktop
- 7.3 kg
- Max Media Size
- Roll (25.4 cm)
- Max Media Size (Custom)
- 254 mm
- Print Speed
- Up to 360 char/sec - max speed , Up to 63 char/sec - near letter
- Max Resolution (B&W)
- 240 x 216 dpi
- Interface
- Parallel
- RAM Installed (Max)
- 12 KB
- Language Simulation
- EPSON FX, IBM PPR
- Media Type
- Envelopes, plain paper, continuous forms
- Enclosure Colour
- White
- 3-year warranty with product registration
- 39.8 cm x 34.5 cm x 11.6 cm
- Printer Type
- Personal printer - dot-matrix - 9 pin - monochrome
- Form Factor
- Desktop
- Enclosure Colour
- White
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Parallel
- 240 x 216 dpi
- PostScript Support
- Not available
- EPSON FX, IBM PPR
RAM
- 12 KB
Media Handling
- Media Path Type
- Curved
- Media Type
- Max Media Size
- Roll (25.4 cm)
- 254 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), Roll (25.4 cm), Roll (7.6cm)
- Media Feeders
- 1 x manual
- Max Sheets in Multi-Part Form
- 5
Duty Cycle
- Cartridge / Printhead Duty Cycle
- 200 million characters
- Cartridge / Printhead Included Qty
- 1
- Connections
- 1 x parallel - 36 PIN Centronics
- MTBF
- 5000 hour(s)
- Power Device
- Power supply - internal
- Voltage Required
- ± 10%
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- Sound Emission
- 57 dBA
- 39.8 cm
- 34.5 cm
- 11.6 cm
- 7.3 kg
OKI ML - 182 / 192 / 280 / 320 / 3320 Black | In Stock | £10.08 |
