The Microline 280 Elite is Oki's smallest dot matrix printer offering perfect print quality at very low cost. High reliability and very compact dimensions make it especially suited for front/back office applications and industrial environments (multipart forms, logs, labels etc.) The Microline 280 Elite is ideal for integration into measurement and control systems.
- OKI Microline 280 Elite - printer - B/W - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 9 pin - B/W
- 4.5 kg
- Media Size Class
- Legal
- Max Media Size
- Legal (216 x 356 mm), continuous paper 76.2 mm - 254 mm (width)
- Min Media Size (Custom)
- 76.2 mm
- Max Media Size (Custom)
- 254 mm
- Print Speed
- Up to 375 char/sec - max speed , Up to 333 char/sec - fast draft , Up to 250 char/sec - normal , Up to 250 char/sec - normal , Up to 62.5 char/sec - near letter , Up to 62.5 char/sec - near letter
- Max Resolution (B&W)
- 240 x 216 dpi
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON FX, Okidata Microline, IBM Graphics
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, Code 128B, Code 128C, Code 128A
- Media Type
- Labels, plain paper, continuous forms, cards
- Media Handling
- Bottom paper feeder, rear paper feeder, top paper feeder
- 3-year warranty with product registration
- 37.2 cm x 27.5 cm x 8 cm
- Printer Type
- Personal printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 375 char/sec - max speed - 12 cpi , Up to 333 char/sec - fast draft - 10 cpi , Up to 250 char/sec - normal - 12 cpi , Up to 250 char/sec - normal - 10 cpi , Up to 62.5 char/sec - near letter - 12 cpi , Up to 62.5 char/sec - near letter - 10 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 240 x 216 dpi
- Fonts Included
- 1 x barcode , 1 x scalable
- Barcodes
- Media Handling
RAM
- 128 KB
Media Handling
- Media Path Type
- Curved, straight
- Media Type
- Media Size Class
- Legal
- Max Media Size
- 76.2 mm
- 254 mm
- Media Sizes
- Media Weight
- 35 g/m² - 90 g/m²
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width) weight: 35 g/m² - 52 g/m² , 1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width) weight: 35 g/m² - 52 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 50 g/m² - 90 g/m²
- Max Sheets in Multi-Part Form
- 4
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x ribbon (black) - up to 3 million characters , 1 x printhead - up to 200 million characters
- MTBF
- 20,000 hour(s)
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- Software Included
- Driver
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 51 dB
- 37.2 cm
- 27.5 cm
- 8 cm
- 4.5 kg
