The MC851 is a truly integrated, network ready multifunction product that can print, copy, scan and fax bringing extra productivity, capability and cost-savings to the busy workgroup and small business. With networking as standard, the MC851cdtn also has integrated duplex capabilities, for double-sided printing. The cabinet provides extra storage space whilst the 2nd tray provides an additional 530-sheet capacity allowing print to continue for longer without user intervention.
- OKI MC851dn - multifunction printer (colour)
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 60000 impressions
- Recommended Monthly Volume
- 8000 pages
- Max Copying Speed
- Up to 34 ppm (mono) / up to 22 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 400 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- Parallel, USB 2.0, LAN
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 56.5 cm x 65.8 cm x 66.9 cm
- 68 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3 years warranty with product registration
- Copier Type
- Digital
- Fax Type
- Plain paper
- LED - colour
- 60000 impressions
- 8000 pages
- Display Features
- Touch screen
- Interface
- Standard Memory
- 512 MB
- Max Supported Memory
- 768 MB
- Hard Disk Drive
- 40 GB
Copying
- Max Copying Speed
- Preset Enlargements
- 400%
- Preset Reductions
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 11.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 1000 pages
Fax Machine Features
- Speed Dialing
- 500 station(s)
- Broadcast Transmission
- 530 stations
- Group dialling
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A3
- Min Media Weight
- 42 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
- 400 sheets
- 100 sheets
- 250 sheets
- ADF - 50 sheets - A3 (297 x 420 mm) weight: 42 g/m² - 128 g/m² , Bypass tray - 100 sheets - 297 x 1200 mm weight: 64 g/m² - 200 g/m² , Input tray - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Copying: up to 34 ppm (A4) - B/W , Copying: up to 22 ppm (A4) - colour , Printing: up to 34 ppm (A4) - B/W , Printing: up to 22 ppm (A4) - colour , Printing: up to 17 ppm (A3) - B/W , Printing: up to 12 ppm (A3) - colour
- 1 x USB 2.0 , 1 x parallel , 1 x LAN
- Network Protocols
- TCP/IP, NetBEUI, LPR/LPD, SMB, SNMP, HTTP, HTTPS, IPv4, IPv6, Bonjour, FTP, SMTP
- Kerberos, Secure Print, SSL, TLS, IPsec, 802.1x
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple MacOS X 10.3.9 or later, MS Windows Server 2008, MS Windows Server 2008 R2
- Software Included
- OKI Color Correct Utility, OKI Print Control Software, OKI LPR, OKI Storage Device Manager, Nuance PaperPort SE 11, Nuance OmniPage SE 16
- Voltage Required
- 700 Watt
- Power Consumption Standby
- 160 Watt
- Power Consumption Sleep
- 25 Watt
- Warm-Up Time
- 90 sec
- First Copy Out Time B/W
- 13 sec
- First Copy Out Time Colour
- 16 sec
- Consumables Included
- 1 x Cartridge (black) - up to 2000 pages , 1 x Cartridge (cyan) - up to 2000 pages , 1 x Cartridge (magenta) - up to 2000 pages , 1 x Cartridge (yellow) - up to 2000 pages
- ENERGY STAR Certified
- Limited warranty - 3 years
- 56.5 cm
- 65.8 cm
- 66.9 cm
- 68 kg
- Sound Emission
- 37 dBA (idle) / 54 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
