The MC770 multifunction printers provide high-demand performance and reliability, while maintaining a low cost per copy and low total cost of ownership. Highlighted features include high print and copy speeds (42/42 ppm), legal flatbed scanners, high toner yields, and embedded open API platform for document management. These MFPs can additionally be configured with expanded paper trays and feeders, internal finishing capabilities, as well as a dealer - installed wireless functionality.
Efficient connectivity
With interfaces like Gigabit Ethernet, USB 2.0, and USB host, along with comprehensive security protocols including ARP, Apple Bonjour, IP filtering, LDAP, MAC address filtering, SSL, Secure Print, and TLS, this device ensures secure and versatile connectivity options for all office environments. -
Advanced copying capabilities
Boasts automatic duplexing, ID Card Copy feature, and impressive copying speeds up to 36 ppm for black and white and 34 ppm for color, alongside a first copy out time as fast as 13 seconds. With a maximum copying resolution of 600 DPI for both color and black and white, it delivers high-quality copies efficiently. -
High-capacity document handling
Designed to meet the demands of high-volume tasks with a bypass feeder capacity of 100 sheets, document feeder capacity of 100 sheets, and a maximum media capacity of 3160 sheets. Supports a wide range of media sizes and types, including envelopes and plain paper, facilitating versatile document management. -
Intuitive user interface
Features a 23 cm touchscreen display for easy navigation and control, enhancing user experience and productivity. -
Eco-friendly and energy-efficient
ENERGY STAR certified, ensuring efficient power consumption with an operational power consumption of 800 W, standby power consumption of 130 W, and a sleep mode power consumption of just 2 W, making it an environmentally friendly choice for any office.
- OKI MC770dnfax - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Max Copying Speed
- Up to 36 ppm (mono) / up to 34 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 216 x 1321 mm (max)
- Media Type
- Envelopes, plain paper, labels
- Standard Media Capacity
- 630 sheets
- Max Media Capacity
- 3160 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 520 sheets
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network, sXP (smart Extendable Platform)
- Power
- AC 230 V (50/60Hz)
- 52.2 cm x 60.4 cm x 67.5 cm
- 50 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Fax Type
- Plain paper
- LED - colour
- Display Features
- Touch screen
- Interface
- Standard Memory
- 2 GB
- Hard Disk Drive
- 160 GB
Copying
- Max Copying Speed
- Preset Enlargements
- 400%
- Preset Reductions
- 25%
- Maximum Copies
- 999
- Copying Features
- ID Card Copy
Printing
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 9 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 1000 pages
Fax Machine Features
- Speed Dialing
- 1000 station(s)
- Broadcast Transmission
- 400 stations
- Group dialling
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 100 sheets
- Max Media Size
- A4
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
- 630 sheets
- 3160 sheets
- 100 sheets
- 520 sheets
- ADF - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 216 x 1321 mm weight: 64 g/m² - 250 g/m² , Input tray - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Output tray - 500 sheets , Stapler - 20 sheets
- Speed Details
- Copying: up to 36 ppm (A4) - B/W , Copying: up to 34 ppm (A4) - colour , Printing: up to 36 ppm (A4) - B/W , Printing: up to 34 ppm (A4) - colour , Scanning: up to 40 ipm - B/W , Scanning: up to 40 ipm - colour
Finishing Equipment
- Stapler
- Included
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- LDAP, Secure Print, SSL, Apple Bonjour, TLS, IP filtering, ARP, MAC address filtering
- Operating System Support
- UNIX, Linux, MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista SP1, MS Windows 7 64-bit Edition, MS Windows Vista SP2, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2008 SP1, MS Windows Server 2003 SP2, Windows 8 64-bit
- Software Included
- Drivers & Utilities, OKI PrintSuperVision, OKI Template Manager
- Voltage Required
- 800 Watt
- Power Consumption Standby
- 130 Watt
- Power Consumption Sleep
- 2 Watt
- Warm-Up Time
- 60 sec
- First Copy Out Time B/W
- 13 sec
- First Copy Out Time Colour
- 13 sec
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- GS
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
- 52.2 cm
- 60.4 cm
- 67.5 cm
- 50 kg
- Sound Emission
- 37 dBA (idle) / 57 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
OKI MC760/770/780 Transfer Belt | In Stock | £102.29 |
OKI MC760/770/780 Yellow Image Drum 30K | In Stock | £252.86 |
OKI MC760/770/780 Cyan Image Drum 30K | In Stock | £252.86 |
