The MC363dn multifunction printer (MFP) sets standards for small business printers, offering unparalleled value and putting outstanding functionality within reach of every organization. Ultra-fast and designed to handle graphics-rich documents with ease, this compact device can help any business build its brand on a budget, printing color materials to a professional quality to save on outsourcing. Offering duplex printing, scanning, copying and faxing.
Efficient connectivity
With a variety of interfaces including Gigabit Ethernet, USB 2.0, and USB 2.0 host, the OKI MC363dn ensures seamless connection across multiple devices, enhancing office productivity. -
Advanced security
The device comes equipped with robust security protocols such as 802.1x, IP filtering, IPsec, MAC address filtering, SSL, and TLS, safeguarding sensitive information against unauthorized access. -
High-quality copying
Automatic duplexing, ID Card Copy, and collation copy features, combined with a first copy out time as fast as 12 sec for B/W and 14 sec for color, make document reproduction both quick and efficient. -
Versatile media handling
Supports a wide range of media sizes and types, including envelopes, plain paper, photo paper, and banners, making it suitable for various printing needs. -
Eco-friendly operation
With a sound emission of just 37 dBA in idle mode and low power consumption in sleep and standby modes, the OKI MC363dn operates efficiently while minimizing environmental impact.
- OKI MC363dn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 45000 impressions
- Recommended Monthly Volume
- 5000 pages
- Max Copying Speed
- Up to 24 ppm (mono) / up to 22 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 30 ppm (mono) / up to 26 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 210 x 1320 mm (max)
- Media Type
- Envelopes, plain paper, cards, photo paper, banner
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 880 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, scan to FTP
- Power
- AC 120/230 V (50/60Hz)
- 42.7 cm x 50.9 cm x 44.4 cm
- 29 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Fax Type
- Plain paper
- LED - colour
- 45000 impressions
- 5000 pages
- Interface
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, IBM Proprinter, PDF 1.7, PCL 6 (XL 3.0), EPSON FX
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- First Print Out Time B/W
- 8.5 sec
- First Print Out Time Colour
- 9 sec
- Colour Management Features
- ICC Color Profiles
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 200 pages
Fax Machine Features
- One-Touch Dialing
- 16 station(s)
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Group dialling
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 210 x 1320 mm, 75 x 125 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Borderless Photo Sizes
- 102 x 152 mm, 127 x 178 mm
- 350 sheets
- 880 sheets
- 100 sheets
- 150 sheets
- RADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 210 x 1320 mm weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 26 ppm (A4) - colour , Scanning: up to 30 spm - B/W , Scanning: up to 30 spm - colour
- 1 x USB 2.0 , 1 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.8.5 - 10.11
- Software Included
- OKI PrintSuperVision, OKI Color Swatch Utility, OKI Color Correct Utility, OKI Template Manager, ABBYY FineReader 12 Sprint, OKI Configuration Tool, OKI Driver Installer, OKI Firmware Update Tool, OKI Front End Installer, OKI LPR Utility, OKI Maintenance Utility, OKI Network Card Setup, OKI Network Extension, OKI PDF Print Direct, OKI Print Job Accounting Client, OKI Profile Assistant, OKI PS Gamma Adjuster, OKI Scanner Driver (ICA), OKI Universal FAX Driver, OKI Universal Scanner Driver (TWAIN), OKI Universal Scanner Driver (WIA), OKI Web Driver Installer
- Voltage Required
- 570 watt
- Power Consumption Standby
- 100 watt
- Power Consumption Sleep
- 1.5 watt
- Warm-Up Time
- 60 sec
- First Copy Out Time B/W
- 12 sec
- First Copy Out Time Colour
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
- ENERGY STAR Certified
- Limited warranty - 3 years
- 42.7 cm
- 50.9 cm
- 44.4 cm
- 29 kg
- Sound Emission
- 37 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
