OKI MC363dn-2AC A4 Colour Laser Multifunction Printer
Quicklinx: CGS7WS00 Mfr#: 46553201
The MC363dn multifunction printer (MFP) sets standards for small business printers, offering unparalleled value and putting outstanding functionality within reach of every organization. Ultra-fast and designed to handle graphics-rich documents with ease, this compact device can help any business build its brand on a budget, printing color materials to a professional quality to save on outsourcing. Offering duplex printing, scanning, copying and faxing.
  • Efficient connectivity
    With a variety of interfaces including Gigabit Ethernet, USB 2.0, and USB 2.0 host, the OKI MC363dn ensures seamless connection across multiple devices, enhancing office productivity.
  • Advanced security
    The device comes equipped with robust security protocols such as 802.1x, IP filtering, IPsec, MAC address filtering, SSL, and TLS, safeguarding sensitive information against unauthorized access.
  • High-quality copying
    Automatic duplexing, ID Card Copy, and collation copy features, combined with a first copy out time as fast as 12 sec for B/W and 14 sec for color, make document reproduction both quick and efficient.
  • Versatile media handling
    Supports a wide range of media sizes and types, including envelopes, plain paper, photo paper, and banners, making it suitable for various printing needs.
  • Eco-friendly operation
    With a sound emission of just 37 dBA in idle mode and low power consumption in sleep and standby modes, the OKI MC363dn operates efficiently while minimizing environmental impact.
OKI MC363dn - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
45000 impressions
Recommended Monthly Volume
5000 pages
Max Copying Speed
Up to 24 ppm (mono) / up to 22 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 30 ppm (mono) / up to 26 ppm (colour)
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
210 x 1320 mm (max)
Media Type
Envelopes, plain paper, cards, photo paper, banner
Standard Media Capacity
350 sheets
Max Media Capacity
880 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, scan to FTP
AC 120/230 V (50/60Hz)
42.7 cm x 50.9 cm x 44.4 cm
29 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
LED - colour
45000 impressions
5000 pages
Standard Memory
1 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, IBM Proprinter, PDF 1.7, PCL 6 (XL 3.0), EPSON FX
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
First Print Out Time B/W
8.5 sec
First Print Out Time Colour
9 sec
Colour Management Features
ICC Color Profiles
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 200 pages
Fax Machine Features
One-Touch Dialing
16 station(s)
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Group dialling
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 210 x 1320 mm, 75 x 125 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Borderless Photo Sizes
102 x 152 mm, 127 x 178 mm
350 sheets
Max Media Capacity
880 sheets
100 sheets
150 sheets
RADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 210 x 1320 mm weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 26 ppm (A4) - colour , Scanning: up to 30 spm - B/W , Scanning: up to 30 spm - colour
1 x USB 2.0 , 1 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.8.5 - 10.11
Software Included
OKI PrintSuperVision, OKI Color Swatch Utility, OKI Color Correct Utility, OKI Template Manager, ABBYY FineReader 12 Sprint, OKI Configuration Tool, OKI Driver Installer, OKI Firmware Update Tool, OKI Front End Installer, OKI LPR Utility, OKI Maintenance Utility, OKI Network Card Setup, OKI Network Extension, OKI PDF Print Direct, OKI Print Job Accounting Client, OKI Profile Assistant, OKI PS Gamma Adjuster, OKI Scanner Driver (ICA), OKI Universal FAX Driver, OKI Universal Scanner Driver (TWAIN), OKI Universal Scanner Driver (WIA), OKI Web Driver Installer
570 watt
Power Consumption Standby
100 watt
Power Consumption Sleep
1.5 watt
Warm-Up Time
60 sec
First Copy Out Time B/W
12 sec
First Copy Out Time Colour
14 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
ENERGY STAR Certified
Limited warranty - 3 years
42.7 cm
50.9 cm
44.4 cm
29 kg
Sound Emission
37 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
20 - 80%
