The MC332dn is the perfect print, scan and copy device for a micro business or home office with a low usage and print volume requirement. Color print speeds of 20 ppm and mono print speeds of 22 ppm provide the user with the flexibility to print their marketing materials in-house.
- OKI MC332dn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 2000 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Display
- 3.5"
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 210 x 1320 mm (max)
- Media Type
- Envelopes, plain paper, cards, photo paper, banner
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 350 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 42.7 cm x 50.9 cm x 44.4 cm
- 29 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- LED - colour
- 30000 pages
- 2000 pages
- Display Diagonal Size
- 3.5"
- Interface
- Standard Memory
- 256 MB
- Max Supported Memory
- 768 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, IBM Proprinter
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- First Print Out Time B/W
- 8.5 sec
- First Print Out Time Colour
- 9 sec
- Colour Management Features
- ICC Color Profiles
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 75 x 125 mm, 125 x 175 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
- 350 sheets
- 350 sheets
- 100 sheets
- 150 sheets
- RADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 210 x 1320 mm weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , Output tray - 150 sheets
- Speed Details
- Copying: up to 22 ppm - B/W , Copying: up to 20 ppm - colour , Printing: up to 22 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Scanning: up to 20 ppm - colour , Scanning: up to 30 ppm - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, IP filtering, ARP, MAC address filtering
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.3.9 - 10.8
- Software Included
- OKI PrintSuperVision, OKI Color Swatch Utility, OKI Color Correct Utility, OKI Template Manager, OKI LPR, Nuance PaperPort SE 11, Nuance OmniPage SE 16
- Voltage Required
- 500 Watt
- Power Consumption Standby
- 100 Watt
- Power Consumption Sleep
- 1.2 Watt
- Warm-Up Time
- 60 sec
- First Copy Out Time B/W
- 12 sec
- First Copy Out Time Colour
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 750 pages , 1 x toner cartridge (cyan) - up to 750 pages , 1 x toner cartridge (magenta) - up to 750 pages , 1 x toner cartridge (yellow) - up to 750 pages
- Supported Windows 7 Features
- Windows HD Imaging
- ENERGY STAR Certified
- Limited warranty - 3 years
- 42.7 cm
- 50.9 cm
- 44.4 cm
- 29 kg
- Sound Emission
- 33 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
