OKI MB 451dn Mono LED Multifunction Printer
Quicklinx: 8CNVWS00 Mfr#: 01327201
The MB451dn all-in-one printer delivers amazing value with its unrivaled fusion of performance, functionality and price. It's a 29 pages per minute (ppm) network printer with flexible media handling and an automatic duplex unit built-in to save paper. Unusually at this price point the MB451dn has a Reverse Automatic Document Feeder (RADF), powerful image processing and a large memory for fast copying, scanning and faxing of double sided documents. And with dedicated function buttons, speed dialing to send faxes and a graphic display it's really easy to use.
When fax functionality is a must, the MB451dn is the perfect device for the lower print volume requirements of the person.
OKI MB451dn - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 29 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 29 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Display
3.5"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
210 x 1321 mm (max)
Media Type
Envelopes, plain paper, banner
Standard Media Capacity
350 sheets
Max Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, USB host
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to application, scan to network
AC 230 V (50/60Hz)
42.7 cm x 42.5 cm x 45.5 cm
20 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
LED - monochrome
30000 pages
2000 pages
Display Diagonal Size
3.5"
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Up to 29 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 29 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, IBM Proprinter
Automatic Duplexing
First Print Out Time B/W
5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 200 pages
Fax Machine Features
One-Touch Dialing
16 station(s)
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Group dialling
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
160 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
350 sheets
Max Media Capacity
350 sheets
100 sheets
150 sheets
Bypass tray - 100 sheets - 210 x 1321 mm weight: 60 g/m² - 160 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Output tray - 150 sheets , ADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m²
Speed Details
Copying: up to 29 ppm - B/W , Printing: up to 29 ppm - B/W , Scanning: up to 37.5 ppm - B/W , Scanning: up to 10 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
SSL, TLS, IPsec, 802.1x, IP filtering, ARP, MAC address filtering
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.4 - 10.7.2
Software Included
OKI PrintSuperVision, OKI Template Manager, OKI Network Setup Tool, OKI LPR, Nuance PaperPort SE 11, Nuance OmniPage SE 16
AC 230 V (50/60Hz)
580 Watt
Power Consumption Standby
80 Watt
Power Consumption Sleep
14 Watt
First Copy Out Time B/W
11 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages
Supported Windows 7 Features
Windows HD Imaging
ENERGY STAR Certified
Limited warranty - 3 years
42.7 cm
42.5 cm
45.5 cm
20 kg
Sound Emission
30 dBA (idle) / 55 dBA (operating)
10 °C
32 °C
20 - 80%
8CNV OKI B401 Black Toner - 2.5k In Stock £79.28
8CNV OKI B401/MB441/451 Black Toner 1.5K In Stock £64.84
