OKI C843dn-2AC A4 Colour Laser Printer
Quicklinx: CGS6WS00 Mfr#: 46550707
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Smallest A3 colour printer where space is a premium offering outstanding print quality
Key features-
  • Smallest footprint A3 printer on the market perfect for retail
  • Excellent media flexibility - A6 to A3 and up to 1321mm banners
  • Up to 35ppm colour print speed
  • Fast duplex printing (optional on n variants)
  • Paper capacity up to 1990 sheets and media weights between 64 and 256gsm
  • Excellent 1200 x 1200dpi print quality (C843dn)
  • Citrix XenApp 7.6 compatibility - ideal for virtual network environment
Advanced connectivity-
  • Wireless Direct offers safe simultaneous connection of wired and wireless networking
  • Optional Wireless LAN Module available
  • Gigabit Ethernet enables fast transfer of large colour files across the network
  • Google Cloud Print 2.0 ready enabling printing on the move
Easy to use-
  • Easy to set-up and get started
  • Store templates and documents on the device for all users to print without authentication (Shared Print)
  • When new features are available you can update the device via the OKI portal
Cost and energy saving-
  • Print marketing materials in-house thanks to outstanding print quality and media flexibility
  • Deep Sleep mode saves energy Auto-Off mode automatically powers down to less than 0.5W when not in use
  • Toner Save to reduce cost when printing draft or internal documents
  • Duplex printing reduces paper usage • Mono only printing when colour cartridges are empty
  • Efficient productivity
    With automatic duplexing and speeds up to 35 ppm in both color and B/W, the OKI C843dn ensures high-efficiency printing for all your business needs. Its first print out time of just 9.5 seconds for both color and B/W documents means you can expect rapid output without sacrificing quality.
  • Versatile media handling
    The OKI C843dn excels in versatility, supporting media sizes up to A3 (297 x 420 mm) and weights ranging from 64 to 256 g/m2. With a total media capacity of 400 sheets, including a 100-sheet multipurpose tray and a 300-sheet input tray, it accommodates a wide range of printing tasks from envelopes to large format documents.
  • Advanced connectivity
    Equipped with Gigabit Ethernet, USB 2.0, and USB 2.0 host interfaces, the OKI C843dn offers flexible connectivity options for seamless integration into any work environment. This ensures easy sharing among multiple users and compatibility with a variety of devices and networks.
  • Superior print quality
    Achieve professional-grade print quality with the OKI C843dn, which delivers resolutions up to 1200 x 1200 DPI for both color and B/W printing. This ensures crisp, clear text and vibrant images for all your documents, presentations, and marketing materials.
  • Eco-friendly operation
    With ENERGY STAR certification, the OKI C843dn printer operates efficiently, consuming only 1 watt in sleep mode and 12 watts in standby. This not only helps reduce your office's energy consumption but also contributes to a lower total cost of ownership.
OKI C843dn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
40 kg
North America
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
148.5 mm x 182 mm
Max Media Size (Custom)
297 mm x 1321 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 20 ppm - B/W - A3 (297 x 420 mm) , Up to 20 ppm - colour - A3 (297 x 420 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
RAM Installed (Max)
512 MB (768 MB)
Flash Memory Installed (Max)
(16 GB)
Language Simulation
PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
Media Type
Envelopes, plain paper
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
5000 pages
Print server
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
3-year warranty with product registration
44.9 cm x 55.2 cm x 36 cm
Printer Type
North America
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
9.5 sec
Language Simulation
Fonts Included
87 x scalable PCL , 80 x PostScript , 1 x bitmapped PCL , 1 x barcode
Barcodes
Media Handling
RAM
RAM Installed (Max)
512 MB / 768 MB (max)
Flash Memory
Flash Memory
16 GB (max)
Card Reader
Supported Flash Memory Cards
SDHC Memory Card
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
148.5 mm x 182 mm
297 mm x 1321 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
400 sheets
Media Feeders
1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets weight: 64 g/m² - 256 g/m²
Max Media Capacity
2005 sheets
Output Trays Capacity
250 sheets
Duty Cycle
75000 pages
5000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, HTTP
Security Protocols & Features
SSL, TLS, IPsec, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798
Power supply - internal
Frequency Required
50/60 Hz
700 Watt
Power Consumption Stand by
12 Watt
Power Consumption Sleep
1 Watt
Software Included
OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Color Swatch Utility, OKI Network Extension, OKI Template Manager, OKI PS Gamma Adjuster, OKI Print Job Accounting, OKI Configuration Tool, OKI Firmware Update Tool, OKI Network Card Setup
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
52 dBA
44.9 cm
55.2 cm
36 cm
40 kg
CGS6 OKI C831/C841 Fuser Unit In Stock £110.10
CGS6 OKI C822/831/841 Transfer Belt In Stock £106.63
