The C822 is the perfect A3/A4 color printer for a micro or small businesses or workgroups. You will benefit from extensive media flexibility from A6 to A3 and high quality output so you can print your day-to-day business documents from one compact device. And with a low initial capital outlay, the C822 makes in-house color printing more accessible even when budgets are tight.
Fast, robust and superb color print quality
The C822 is built on tried and tested LED technology that your business can rely on to deliver over and over again. -
Excellent media flexibility to support your business
The C822 provides complete flexibility, enabling users to print on a wide range of media sizes, formats and paper weights.
- OKI C822n - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 37 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Min Media Size (Custom)
- 148.5 mm x 182 mm
- Max Media Size (Custom)
- 297 mm x 1321 mm
- Print Speed
- Up to 23 ppm - B/W - A4 (210 x 297 mm) , Up to 23 ppm - colour - A4 (210 x 297 mm) , Up to 13 ppm - B/W - A3 (297 x 420 mm) , Up to 13 ppm - colour - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Max Resolution (Colour)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Interface
- USB, LAN
- Processor
- 800 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5C, EPSON FX, IBM PPR, PCL 6
- Barcodes
- OCR-A, OCR-B, ZIP
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 400 sheets
- Media Handling
- 100-sheet multipurpose tray, 300-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 5000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- Printer Features
- Optional duplex
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Apple MacOS X 10.3.9 - 10.7
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty with product registration
- 44.9 cm x 55.2 cm x 36 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 x 600 dpi
- 1200 x 600 dpi
- First Print Out Time B/W
- 14 sec
- First Print Out Time Colour
- 14 sec
- Fonts Included
- 87 x scalable PCL , 1 x bitmapped PCL , 1 x barcode
- Barcodes
- OCR-A, OCR-B, ZIP
- Printer Features
- Optional duplex
- Media Handling
- Processor
- 800 MHz
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 148.5 mm x 182 mm
- 297 mm x 1321 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm)
- Media Weight
- 64 g/m² - 256 g/m²
- 400 sheets
- Media Feeders
- 1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets weight: 64 g/m² - 256 g/m²
- Max Media Capacity
- 930 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 75000 pages
- 5000 pages
- Networking
- Print server
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, HTTPS
- Secure Print, SSL, TLS, 802.1x, IP filtering, MAC address filtering
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 700 Watt
- Power Consumption Stand by / Sleep
- 12 Watt
- Software Included
- OKI LPR, OKI PrintSuperVision.net, OKI Web Driver Installer, OKI Web Print, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Swatch Utility, OKI Template Manager, OKI Color Access Policy Manager
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 52 dBA
- 44.9 cm
- 55.2 cm
- 36 cm
- 37 kg
OKI C822 Yellow Toner 7K | In Stock | £200.90 |
OKI C822 MagentaToner 7K | In Stock | £200.90 |
OKI C822 CyanToner 7K | In Stock | £200.90 |
OKI C822 BlackToner 7K | In Stock | £84.51 |
OKI C822/831/841 MAGENTA Image Drum 30K | In Stock | £141.48 |
OKI C822/831/841 Cyan Image Drum 30K | In Stock | £141.48 |
OKI C822/831/841 Black Image Drum 30K | In Stock | £141.48 |
OKI C822/831/841 Yellow Image Drum 30K | In Stock | £141.48 |
OKI C822 Fuser Unit | In Stock | £97.92 |
