OKI C712n-2AC A4 Colour Laser Printer
Quicklinx: CGRTWS00 Mfr#: 46551101
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Key features
  • Low running costs
  • Fast duplex printing at 34ppm colour/36ppm in mono
  • Generous paper capacity up to 1690 sheets for large workgroups
  • Prints on stocks up to 250gsm – heavier than any comparable printer
  • Security features protect sensitive information and IP
  • Store templates and documents on the device for all users to print without authentication (Shared Print)
  • Citrix XenApp 7.6 compatibility - ideal for virtual network environment
Advanced connectivity
  • Wireless Direct feature offers safe simultaneous connection of wired and wireless networking
  • Gigabit Ethernet enables fast transfer of large colour files across the network
  • Google Cloud Print 2.0 ready enabling printing on the move
  • Optional Wireless LAN Module available
Cost and energy saving
  • Print marketing materials in-house thanks to outstanding print quality and media flexibility
  • Deep Sleep mode saves energy Auto-Off mode automatically powers down to less than 0.5W when not in use
  • Toner Save to reduce cost when printing draft or internal documents
  • Duplex printing reduces paper usage (optional on C712n)
  • Free consumables recycling programme
  • LED technology means no moving parts for a longer life
  • Efficient productivity
    Designed for high-volume printing, the OKI C712n has a recommended monthly volume of 6000 pages, ensuring it meets the demands of busy work environments.
  • Versatile media handling
    With a media handling system that supports sizes from A6 to A4 and types ranging from plain paper to envelopes, this printer is equipped to handle diverse printing needs.
  • High-quality output
    Leveraging OKI ProQ2400 Multilevel image enhancement technology, the C712n delivers sharp, vibrant color and B/W printing at resolutions up to 1200 x 600 DPI.
  • Rapid printing speeds
    Achieve productivity with fast printing speeds of up to 36 ppm for B/W and 34 ppm for color, complemented by quick first print out times of 8 sec for B/W and 9 sec for color.
OKI C712n - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
29 kg
Media Size Class
A4/Legal
Max Media Size
216 x 1321 mm
Min Media Size (Custom)
64 mm x 127 mm
Max Media Size (Custom)
216 mm x 1321 mm
Print Speed
Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
Automatic Duplexing
Optional
USB 2.0, Gigabit LAN
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, ZIP, OCR-A, OCR-B
Media Type
Envelopes, plain paper, banners, postcards
Total Media Capacity
630 sheets
Media Handling
100-sheet multipurpose tray, 530-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
6000 pages
Print server
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11, Linux
3-year warranty with product registration
43.5 cm x 54.7 cm x 38.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
Optional
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
87 x scalable PCL , 80 x PostScript
Barcodes
Media Handling
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 x 1321 mm
64 mm x 127 mm
216 mm x 1321 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), Statement (139.7 x 215.9 mm), Folio (216 x 330 mm), 76.2 x 127 mm, 75 x 125 mm, 101.6 x 152.4 mm, 127 x 177.8 mm, 100 x 150 mm, 125 x 175 mm, 64 x 127 mm, 216 x 1321 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 250 g/m²
630 sheets
Media Feeders
Input tray: 1 - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Multi-purpose tray: 1 - 100 sheets weight: 64 g/m² - 250 g/m²
Max Media Capacity
1690 sheets
Output Trays Capacity
450 sheets
Duty Cycle
100000 pages
6000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, IPv6
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x, Secure Erase, MAC address filtering, IP filtering
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow) , 4 x drum
Power supply - internal
Frequency Required
50/60 Hz
1300 watt
Power Consumption Stand by
100 watt
Power Consumption Sleep
1.2 watt
Software Included
OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Color Swatch Utility, OKI Color Correct, OKI Template Manager, OKI PDF Print Direct, OKI Network Card Setup, OKI Configuration Tool, OKI PS Gamma Adjuster, OKI Firmware Update Tool, OKI Profile Assistant, OKI Print Job Accounting
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
43.5 cm
54.7 cm
38.9 cm
29 kg
CGRT OKI C610 Fuser Unit In Stock £148.28
CGRT OKI MC760/770/780 Transfer Belt In Stock £102.87
