When productivity in the workplace really matters if your team is taking on tight deadlines and demanding workloads you need a network colour printer you can really depend on. The ultra-reliable digital LED technology rapid throughput and a robust yet compact design deliver enterprise-class performance that just won’t let you down.
And that’s not all. With its superb print quality exceptional media flexibility superior energy efficiency and a genuinely low total cost of ownership the C711 is a solid investment in the future of your business.
Efficient productivity
With a monthly duty cycle of up to 100,000 pages and recommended monthly volume of 6,000 pages, the OKI C712dn is designed to handle high-volume printing with ease, ensuring your office's productivity remains high. -
Advanced connectivity
Featuring Gigabit Ethernet and USB 2.0 interfaces, this printer offers versatile connectivity options for seamless integration into any modern office environment, supporting both Mac and PC compatibility. -
Superior print quality
Equipped with OKI ProQ2400 Multilevel Image Enhancement Technology and a maximum resolution of 1200 x 600 DPI for both black and white and color prints, the OKI C712dn delivers sharp, vivid printouts that capture every detail. -
Flexible media handling
From envelopes to plain paper, and with media sizes ranging from A6 to A4, the printer's versatile media handling capabilities allow for a wide range of printing tasks, supported by a 630-sheet total media capacity. -
Secure and reliable
Incorporating advanced security protocols including SSL, Secure Print, and IPsec, alongside robust remote management features, the OKI C712dn ensures your documents are both safe and easily manageable across networks.
- OKI C712dn - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 32 kg
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 1321 mm
- Min Media Size (Custom)
- 64 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 1321 mm
- Print Speed
- Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Max Resolution (Colour)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
- Media Type
- Envelopes, plain paper, banners, postcards
- Total Media Capacity
- 630 sheets
- Media Handling
- 100-sheet multipurpose tray, 530-sheet input tray
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 6000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
- 3-year warranty with product registration
- 43.5 cm x 60.4 cm x 38.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 600 dpi
- 1200 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 9 sec
- Fonts Included
- 87 x scalable PCL , 80 x PostScript
- Barcodes
- Media Handling
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 1321 mm
- 64 mm x 127 mm
- 216 mm x 1321 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, Folio (216 x 330 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 127 x 177.8 mm, 216 x 1321 mm, 75 x 125 mm, 125 x 175 mm, 64 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 64 g/m² - 250 g/m²
- 630 sheets
- Media Feeders
- Input tray: 1 - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Multi-purpose tray: 1 - 100 sheets weight: 64 g/m² - 250 g/m²
- Max Media Capacity
- 1690 sheets
- Output Trays Capacity
- 450 sheets
Duty Cycle
- 100000 pages
- 6000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, IPv6
- Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x, IP filtering, MAC address filtering, Secure Erase
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow) , 4 x drum
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1300 Watt
- Power Consumption Stand by
- 100 Watt
- Power Consumption Sleep
- 1.2 Watt
- Software Included
- OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Color Swatch Utility, OKI Template Manager, OKI PDF Print Direct, OKI PS Gamma Adjuster, OKI Print Job Accounting, OKI Configuration Tool, OKI Firmware Update Tool, OKI Network Card Setup
- OS Required
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 54 dBA
- 43.5 cm
- 60.4 cm
- 38.9 cm
- 32 kg
