When productivity in the workplace really matters, if your team is taking on tight deadlines and demanding workloads, you need a network color printer you can really depend on. The ultra-reliable digital LED technology, rapid throughput and a robust yet compact design deliver enterprise-class performance that just won't let you down.
And that's not all. With its superb print quality, exceptional media flexibility, superior energy efficiency and a genuinely low total cost of ownership, the C711 is a solid investment in the future of your business.
Handle heavy workloads with ease
Flat paper path copes more easily with high print volumes. Heavy-duty materials, rugged components and ultra-reliable digital LED technology. -
Reduce and control your print costs
Attractive price tag and low cost per page. Color access policy manager lets you control and monitor the use of color. -
Professional print quality
Microfine high definition toner ensures documents are sharper, crisper and glossier, even on ordinary office paper. -
Impeccable security
Now you can remove the risk of sensitive information falling into the wrong hands with the secure print utility. A print run can only start when you enter your private PIN at the printer, and data is encrypted before sending and securely erased after use.
- OKI C711n - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 28 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Max Resolution (Colour)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Interface
- Parallel, USB, LAN
- Processor
- 533 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Flash Memory Installed (Max)
- (16 GB)
- Language Simulation
- PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
- Barcodes
- UPC-A, UPC-B, ZIP
- Media Type
- Envelopes, transparencies, labels, plain paper, banner paper
- Total Media Capacity
- 630 sheets
- Media Handling
- 100-sheet multipurpose tray, 530-sheet input tray
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 6000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - internal
- Printer Features
- Optional duplex
- Power
- AC 230V
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty with product registration
- 43.5 cm x 54.6 cm x 38.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 600 dpi
- 1200 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 9 sec
- Fonts Included
- 136 x PostScript , 87 x PCL
- Barcodes
- UPC-A, UPC-B, ZIP
- Printer Features
- Optional duplex
- Media Handling
- Processor
- 533 MHz
RAM
- 256 MB / 768 MB (max)
Flash Memory
- Flash Memory
- 16 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 64 g/m² - 250 g/m²
- 630 sheets
- Media Feeders
- 1 x automatic - 530 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 250 g/m²
- Max Media Capacity
- 1690 sheets
- Output Trays Capacity
- 350 sheets
Duty Cycle
- 100000 pages
- 6000 pages
- Networking
- Print server - internal
- Data Link Protocol
- TCP/IP, UDP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, BOOTP, DHCP, DNS, POP3, SMB
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, HTTP, NDPS, NDS
- Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x
- Expansion Slots
- Memory
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel
- Supported Windows 7 Features
- Windows HD Imaging
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 600 Watt
- Power Consumption Stand by / Sleep
- 1.2 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 54 dBA
- 43.5 cm
- 54.6 cm
- 38.9 cm
- 28 kg
OKI Yellow Toner 11,5000 pages | In Stock | £176.89 |
OKI C710/C711 Magenta Toner | In Stock | £176.89 |
OKI Cyan toner for C711 | In Stock | £188.96 |
OKI C710/C711 Black Toner - 11K | In Stock | £100.00 |
OKI C711 EP C711 Image Drum Black | In Stock | £73.94 |
OKI C711 Cyan Image Drum | In Stock | £131.24 |
