The C612 with flexible media handling, robust security and low cost of ownership means quality marketing collateral can be printed when needed.
Efficient productivity
With a monthly duty cycle of up to 75,000 pages, the OKI C612dn is designed to meet the demands of high-volume printing environments, ensuring reliable performance and productivity. -
Advanced connectivity
Equipped with Gigabit Ethernet and USB 2.0 interfaces, this printer offers versatile connectivity options for seamless integration into any office network, facilitating easy sharing among multiple users. -
Superior print quality
The OKI ProQ2400 Multilevel image enhancement technology, combined with a maximum resolution of 1200 x 600 DPI for both color and B/W printing, ensures sharp, vivid, and professional-quality outputs. -
Flexible media handling
Supports a wide range of media sizes and types, including envelopes and plain paper, with a total media capacity of 400 sheets. Automatic duplexing enhances efficiency by facilitating double-sided printing. -
Comprehensive language support
Offers broad compatibility with various printing languages, including PCL 5C, PCL 6, PCL XL 3.0, PostScript 3, and more, ensuring the printer can handle a wide variety of document types.
- OKI C612dn - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 30 kg
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 1321 mm
- Min Media Size (Custom)
- 64 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 1321 mm
- Print Speed
- Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Max Resolution (Colour)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
- Media Type
- Envelopes, plain paper, banners, postcards
- Total Media Capacity
- 400 sheets
- Media Handling
- 100-sheet multipurpose tray, 300-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 1500 - 5000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
- 3-year warranty with product registration
- 43.5 cm x 60.4 cm x 34 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 600 dpi
- 1200 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 9 sec
- Fonts Included
- 87 x scalable PCL , 80 x PostScript
- Barcodes
- Media Handling
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 1321 mm
- 64 mm x 127 mm
- 216 mm x 1321 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, Folio (216 x 330 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 127 x 177.8 mm, 216 x 1321 mm, 75 x 125 mm, 125 x 175 mm, 64 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 64 g/m² - 250 g/m²
- 400 sheets
- Media Feeders
- Input tray: 1 - 300 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Multi-purpose tray: 1 - 100 sheets weight: 64 g/m² - 250 g/m²
- Max Media Capacity
- 1460 sheets
- Output Trays Capacity
- 350 sheets
Duty Cycle
- 75000 pages
- 1500 - 5000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, IPv6
- Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x, IP filtering, MAC address filtering, Secure Erase
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow) , 4 x drum
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1300 Watt
- Power Consumption Stand by
- 100 Watt
- Power Consumption Sleep
- 1.2 Watt
- Software Included
- OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Color Swatch Utility, OKI Network Extension, OKI Template Manager, OKI PS Gamma Adjuster, OKI Print Job Accounting, OKI Configuration Tool, OKI Firmware Update Tool, OKI Network Card Setup
- OS Required
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 54 dBA
- 43.5 cm
- 60.4 cm
- 34 cm
- 30 kg
