OKI C612dn-2AC A4 Colour Laser Printer
Quicklinx: CGRRWS00 Mfr#: 46551003
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
The C612 with flexible media handling, robust security and low cost of ownership means quality marketing collateral can be printed when needed.
  • Efficient productivity
    With a monthly duty cycle of up to 75,000 pages, the OKI C612dn is designed to meet the demands of high-volume printing environments, ensuring reliable performance and productivity.
  • Advanced connectivity
    Equipped with Gigabit Ethernet and USB 2.0 interfaces, this printer offers versatile connectivity options for seamless integration into any office network, facilitating easy sharing among multiple users.
  • Superior print quality
    The OKI ProQ2400 Multilevel image enhancement technology, combined with a maximum resolution of 1200 x 600 DPI for both color and B/W printing, ensures sharp, vivid, and professional-quality outputs.
  • Flexible media handling
    Supports a wide range of media sizes and types, including envelopes and plain paper, with a total media capacity of 400 sheets. Automatic duplexing enhances efficiency by facilitating double-sided printing.
  • Comprehensive language support
    Offers broad compatibility with various printing languages, including PCL 5C, PCL 6, PCL XL 3.0, PostScript 3, and more, ensuring the printer can handle a wide variety of document types.
OKI C612dn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
30 kg
Media Size Class
A4/Legal
Max Media Size
216 x 1321 mm
Min Media Size (Custom)
64 mm x 127 mm
Max Media Size (Custom)
216 mm x 1321 mm
Print Speed
Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
Automatic Duplexing
USB 2.0, Gigabit LAN
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
Media Type
Envelopes, plain paper, banners, postcards
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
1500 - 5000 pages
Print server
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
3-year warranty with product registration
43.5 cm x 60.4 cm x 34 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
87 x scalable PCL , 80 x PostScript
Barcodes
Media Handling
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 x 1321 mm
64 mm x 127 mm
216 mm x 1321 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, Folio (216 x 330 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 127 x 177.8 mm, 216 x 1321 mm, 75 x 125 mm, 125 x 175 mm, 64 x 127 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 250 g/m²
400 sheets
Media Feeders
Input tray: 1 - 300 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Multi-purpose tray: 1 - 100 sheets weight: 64 g/m² - 250 g/m²
Max Media Capacity
1460 sheets
Output Trays Capacity
350 sheets
Duty Cycle
75000 pages
1500 - 5000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, IPv6
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x, IP filtering, MAC address filtering, Secure Erase
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow) , 4 x drum
Power supply - internal
Frequency Required
50/60 Hz
1300 Watt
Power Consumption Stand by
100 Watt
Power Consumption Sleep
1.2 Watt
Software Included
OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Color Swatch Utility, OKI Network Extension, OKI Template Manager, OKI PS Gamma Adjuster, OKI Print Job Accounting, OKI Configuration Tool, OKI Firmware Update Tool, OKI Network Card Setup
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
43.5 cm
60.4 cm
34 cm
30 kg
