OKI C610n Colour Laser Printer
Quicklinx: 6KKHWS00 Mfr#: 01269501
If you need a color printer that's fast and robust enough to take care of the needs of your entire team - even at the busiest times - look no further than the C610. Rapid print speeds, class leading media handling, and low energy consumption all combine to make this printer the ideal solution to effortlessly support business workgroups of up to 10 users.
The C610's ability to print on paper stocks of up to 250gsm coupled with Oki's High Definition Color technology means your business can produce color vibrant professional documents in-house with ease. Allowing you to print what you want, when you want it, avoiding unnecessary wastage costs and delays.
The C610 delivers maximum performance at exceptional value for money. Taking care to keep costs to a minimum the C610 has an attractive price tag, high yield toners and a long life image drum. In addition, included ‘in the box' are 3 utilities - print control, color access policy manager and PrintSuperVision. With features allowing you to track, monitor and control print usage and costs.
With integrated network capabilities as standard, the C610n is ideal for meeting the everyday demands of workgroups.
  • Tackle the toughest deadlines
    Thanks to the exceptional 'first page to print' time of just 9 seconds and fast print speeds of up to 36 pages per minute, there's no waiting around for documents to print, helping your team to meet and beat the toughest deadlines.
  • Print on the paper you want
  • Reduce the cost of printing
  • Environmental efficiencies
    At a time when cost savings are paramount, but the pressure to become more environmentally friendly increases, the C610 is a product that can help achieve both, consuming just 1.2 watts in 'sleep' mode.
  • Unrivaled media flexibility
    Print on heavy weight paper and light card paper up to 250 gsm and any size from A6 to A4 through to a 1.2-meter banner.
  • Low cost of ownership
    With the best price: performance ratio in its class, the C610 is inexpensive to own. A low cost per page and energy-saving features give it an impressively low total cost of ownership.
  • Energy-efficient
    Thanks to an advanced processor and efficient design, the C610 consumes less energy than similar printers using as little as 1.2 watts once in 'sleep' mode.
OKI C610n - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
26 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
USB, LAN
533 MHz
RAM Installed (Max)
256 MB (768 MB)
Flash Memory Installed (Max)
(16 GB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, XPS, SIDM, PDF 1.7
Barcodes
UPC-A, UPC-B, ZIP
Media Type
Envelopes, labels, plain paper
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
5000 pages
Print server - Ethernet, Fast Ethernet - integrated
Printer Features
Optional duplex
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition
Microsoft Certification
Certified for Windows Vista
3-year warranty with product registration
43.5 cm x 54.6 cm x 34 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
1200 x 600 dpi
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
136 x PostScript , 87 x PCL
Barcodes
UPC-A, UPC-B, ZIP
Printer Features
Optional duplex
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Flash Memory
Flash Memory
16 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 250 g/m²
400 sheets
Media Feeders
1 x automatic - 300 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 250 g/m²
Max Media Capacity
1460 sheets
Output Trays Capacity
350 sheets
Duty Cycle
75000 pages
5000 pages
Print server - integrated
Network / Transport Protocol
TCP/IP, UDP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, BOOTP, DHCP, DNS, POP3, SMB
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, NDPS, NDS
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x
Expansion Slots
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Supported Windows 7 Features
Windows HD Imaging
Power supply - internal
Frequency Required
50/60 Hz
600 Watt
Power Consumption Stand by / Sleep
1.2 Watt
Software Included
OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Swatch Utility, OKI Web Driver Installer, OKI Gamma Utility, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Template Manager, OKI Color Access Policy Manager
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
43.5 cm
54.6 cm
34 cm
26 kg
6KKH OKI C610 Magenta Toner In Stock £177.69
6KKH OKI C610 Yellow Image Drum In Stock £120.91
6KKH OKI C610 Cyan Image Drum In Stock £120.91
6KKH OKI C610 Fuser Unit In Stock £142.23
6KKH OKI C610/C711 Belt Unit In Stock £111.07
