OKI C610DTN A4 Colour Laser
Quicklinx: 6KKLWS00 Mfr#: 01269002
The C610 delivers fast, versatile and affordable in-house printing for the general office
Overview rightIf you need a colour printer that’s fast and robust enough to take care of the needs of your entire team - even at the busiest times - look no further than the C610. Rapid print speeds, class leading media handling, and low energy consumption all combine to make this printer the ideal solution to effortlessly support business workgroups of up to 10 users.
Tackle the toughest deadlines
Thanks to the exceptional ‘first page to print’ time of just 9 seconds and fast print speeds of up to 36 pages per minute, there’s no waiting around for documents to print, helping your team to meet and beat the toughest deadlines.
Print on the paper you want
The C610’s ability to print on paper stocks of up to 250gsm coupled with Oki’s High Definition Colour technology means your business can produce colour vibrant professional documents in-house with ease. Allowing you to print what you want, when you want it, avoiding unnecessary wastage costs and delays.
Reduce the cost of printing
The C610 delivers maximum performance at exceptional value for money. Taking care to keep costs to a minimum the C610 has an attractive price tag, high yield toners and a long life image drum. In addition, included ‘in the box’ are 3 utilities – Print Control, Colour Access Policy Manager and PrintSuperVision. With features allowing you to track, monitor and control print usage and costs.
Environmental efficiencies
At a time when cost savings are paramount, but the pressure to become more environmentally friendly increases, the C610 is a product that can help achieve both, consuming just 1.2 watts in ‘sleep’ mode. You can also reduce unnecessary paper usage and costs with duplex printing as standard on the C610dn and C610dtn models.
  • HD Color Printing technology
    C610 Series models utilize this unique process for breathtaking output. HD Color Printing technology combines multi-level LED printheads and microfine toner for precise toner placement; deep, saturated colors; and fine detail on regular copy paper and glossy media.
  • Rich color pages at up to 32 per minute
    The C610 Series delivers crisp 1200 x 600 dpi color output, with the first page printing in as little as 9 seconds. Black & white pages print at up to 34 ppm, the first in as little as 8 seconds. The C610 Series supports PCL and PostScript emulations, as well as Windows Vista XPS and PDF Direct Print technologies.
  • Flexible paper handling
    All C610 Series models have a paper capacity of at least 400 sheets: a 300-sheet paper tray plus built-in 100 sheet multipurpose tray for labels, envelopes, transparencies, and index stock up to 140 lb. (250 gsm). Use them to print everything from 3" x 5" cards, 4" x 6" and 5" x 7" photo paper, to banner-size sheets up to 8.5" wide by 52" in length. Since the more sheets a printer holds means fewer user interventions, the C610 Series can further increase your productivity: the C610dtn holds 930 sheets, with its standard 530-sheet 2nd tray.
  • Workgroup connectivity built in
    Share the advantages and efficiencies of any or all of the C610 Series models through the internal OkiLAN 10/100 Base-T print server. Or make them personal printers by connecting through the high-speed USB 2.0 port.
OKI C610dtn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
26 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 1320 mm
Print Speed
Up to 36 ppm - B/W , Up to 34 ppm - colour
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Automatic Duplexing
USB, LAN
533 MHz
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, XPS, SIDM, PDF 1.7
Media Type
Envelopes, labels, plain paper
Total Media Capacity
930 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray, 530-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
1500 - 5000 pages
Print server - Ethernet, Fast Ethernet - integrated
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9 or later, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Vista (32/64 bits)
Microsoft Certification
Certified for Windows Vista
3-year warranty with product registration
43.5 cm x 54.6 cm x 34 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
87 x PCL , 136 x PostScript
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm x 1320 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 250 g/m²
930 sheets
Media Feeders
1 x automatic - 300 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 250 g/m² , 1 x automatic - 530 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m²
Max Media Capacity
1460 sheets
Output Trays Capacity
350 sheets
Duty Cycle
75000 pages
1500 - 5000 pages
Print server - integrated
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP 3
Expansion Slots
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 2000 pages , 1 x toner cartridge (magenta) - up to 2000 pages , 1 x toner cartridge (yellow) - up to 2000 pages , 1 x drum (black) - up to 20000 pages , 1 x drum (cyan) - up to 20000 pages , 1 x drum (magenta) - up to 20000 pages , 1 x drum (yellow) - up to 20000 pages
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Supported Windows 7 Features
Windows HD Imaging
Power supply - internal
Frequency Required
50 - 60 Hz
600 Watt
Power Consumption Stand by / Sleep
1.2 Watt
Software Included
OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Swatch Utility, OKI Web Driver Installer, OKI Gamma Utility, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Template Manager, OKI Color Access Policy Manager
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Operating)
54 dBA
Sound Emission (Quiet Mode)
37 dBA
43.5 cm
54.6 cm
34 cm
26 kg
6KKL OKI C610 Yellow Toner In Stock £175.69
6KKL OKI C610 Magenta Toner In Stock £175.69
6KKL OKI C610 Cyan Toner In Stock £169.94
6KKL OKI C610 Yellow Image Drum In Stock £127.78
6KKL OKI C610 Cyan Image Drum In Stock £127.78
6KKL OKI C610 Fuser Unit In Stock £139.27
6KKL OKI C610/C711 Belt Unit In Stock £117.38
6KKL OKI C610 Magenta Drum In Stock £127.78
