Smart, intuitive A4 colour printing that raises the bar for small businesses and workgroups
Ultra-fast and with a powerful new engine, these printers bring new standards of print quality and document security to small businesses and workgroups. On top of this, the C542dn puts the transformational benefits of smart printers within reach too, incorporating a customisable 7" colour LCD touch screen and OKI’s smart extendable platform (sXP) which provides connectivity into a pull printing fleet.
Efficient working that improves productivity
- Impressive print speeds of 30ppm in colour.
- Paper capacity up to 1,410 sheets with two optional trays.
- 1GB RAM memory for trouble-free printing of graphics-intensive documents.
- Gigabit Ethernet enables fast transfer of large colour files across the network.
- Mobile printing from smartphones and tablets, Google Cloud Print 2.0 ready, as well as being compatible with AirPrint by Apple Inc.
- Store templates and documents on the device for all users to print without authentication (Shared Print).
- Citrix XenApp 7.6 compatibility - ideal for virtual network environment.
Simple to set-up, use and own
- Easy to set-up and get started.
- Video guidance for installation and changing consumables.
- When new features are available you can update the device via the OKI portal.
- Trouble-shooting on the device screen and via OKI Mobile Print app.
- Quiet mode ideal for smaller offices.
Important security features
- Wireless Direct feature offers safe simultaneous connection of wired and wireless networking.
- Keep documents confidential with Private Print and optional Card Release#, so users can view all print jobs before selecting which ones to print.
- Internet Protocol Security (IPSec) compliance, ensuring securing that documents are safely sent and received.
Outstanding print quality and media flexibility
- True 1200 x 1200dpi print resolution for outstanding print quality.
- Flexible media handling - from A6 to 1320mm banners; card stock up to 220gsm.
- Duplex printing as standard.
Cost and energy saving
- Print marketing materials in-house, thanks to outstanding print quality and media flexibility.
- Deep Sleep mode saves energy, Auto-Off mode automatically powers down to less than 0.5W when not in use.
- Toner Save to reduce costs, when printing draft or internal documents.
- Duplex printing reduces paper usage.
- Free consumables recycling programme.
- LED technology means no moving parts for a longer life.
Efficient connectivity
With interfaces for Gigabit Ethernet, USB 2.0, and USB 2.0 host, this printer offers versatile connectivity options for seamless integration into any work environment. -
High-quality printing
Leveraging OKI ProQ2400 Multilevel image enhancement technology, the OKI C 532dn delivers sharp, vibrant color prints and crisp black and white documents at resolutions up to 1200 x 1200 DPI. -
Robust media handling
This printer supports a wide range of media sizes and types, including banners, cards, envelopes, and labels, making it ideal for diverse printing needs. -
Secure and manageable
Featuring advanced security protocols such as 802.1x, IPsec, SSL, and TLS, along with comprehensive remote management capabilities, the OKI C 532dn ensures your data remains secure while offering easy management. -
Eco-friendly operation
With a power consumption as low as 1.1 W in sleep mode and automatic duplexing for reduced paper usage, the OKI C 532dn is designed for energy efficiency and environmental sustainability.
- OKI C532dn - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 23 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Max Media Size (Custom)
- 1320 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- RAM Installed (Max)
- 1 GB
- Flash Memory Installed (Max)
- 3 GB
- Language Simulation
- PCL 5C, PostScript 3, EPSON FX, PCL 6, IBM ProPrinter, XPS, SIDM, PCL XL 3.0, PDF 1.7
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
- Media Type
- Envelopes, labels, plain paper, banners, cards
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 60000 pages
- Recommended Monthly Volume
- 6000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
- 3-year warranty with product registration
- 42.7 cm x 57.1 cm x 27.9 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 7.5 sec
- First Print Out Time Colour
- 7.5 sec
- Fonts Included
- 87 x scalable PCL , 80 x scalable PostScript , 1 x bitmapped PCL , 1 x barcode
- Barcodes
- Colour Management Features
- ICC Color Profiles
- Media Handling
RAM
- 1 GB
Flash Memory
- Flash Memory
- 3 GB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- 1320 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Card / Label Sizes
- US 4 x 6 Card (10 x 15 cm), US 3 x 5 Card (76 x 127 mm)
- Media Weight
- 64 g/m² - 220 g/m²
- 350 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , 1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m²
- Max Media Capacity
- 880 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 60000 pages
- 6000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, HTTP
- SSL, TLS, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2000 pages ISO/IEC 19798
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 670 watt
- Power Consumption Stand by
- 90 watt
- Power Consumption Sleep
- 1.1 watt
- Software Included
- OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Color Swatch Utility, OKI Network Extension, OKI Template Manager, OKI PDF Print Direct, OKI PS Gamma Adjuster, OKI Print Job Accounting, OKI Configuration Tool, OKI Firmware Update Tool, OKI Front End Installer, OKI Maintenance Utility, OKI Network Card Setup
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 54 dBA
- 42.7 cm
- 57.1 cm
- 27.9 cm
- 23 kg
