OKI C110 A4 Colour Laser Printer
Quicklinx: 6616WS00 Mfr#: 01264201
The compact A4 mono and colour printer to suit your budge
Reliable and effortless performance
Compact design ideal for desktop users
Fast 19 pages per minute mono, 5 pages per minute colour
Handles heavier paper weights for flexible media handling
The fast black and white printer that offers low-cost professional colour printing when required. Compact, quiet and easy to use, the C110 fits discretely on your desktop making it the perfect choice for your small / home office.
The C110 is easy to install and has a 200 sheet paper capacity keeping user intervention to a minimum.
With flexible media handling and the convenience of colour, you can now print more effective business documents in-house creating a positive impact on your business.
Benefitting from Energy Star compliance, your carbon footprint and energy bills can be kept to a minimum.
Print speed mono A4:
19ppm
Print speed colour A4:
5ppm
Memory(standard):
16MB
Time to first page:
22 seconds colour, 13 seconds mono
Processing print jobs:
80MHz
Resolution:
1200 x 600 dpi x 1 bit (max)
Duty cycle
250 pages/month (average)
Standard paper input:
200 sheets of 80gsm
Paper types:
A4, A5, B5, Custom 92-216mm x 184-356mm
60-209gsm
Paper output
100 sheets face down
EP-cartridge:
Image drum: up to 45,000 mono pages or up
Toner cartridge:
Black, Cyan, Magenta, Yellow, Toner: 2,500 (A4 pages @ 5%); Cyan, Magenta, Yellow, Toner: 1,500 (A4 pages @ 5%); Printer is shipped with 500 pages @ 5%.
Other consumables:
Fuser kit: up to 50,000 pages
Sharing:
Hi-Speed USB
Emulation(s)
Windows Host Based Printing System
OS Compatibility
Windows 2000 / XP / XP x64 / Vista (32 bit) / Vista (64 bit) / Server 2003 / Server 2003 x64 / Server 2008 / Server 2008 x64
Operating conditions:
10°C to 35°C (15°C to 25°C recommended); Storage: -20°C to 40°C
Humidity:
15% to 85% RH (35% to 70% RH recommended); Storage: 10% to 95% RH
Noise:
Operating: up to 51dB(A), Standby: 29dB (A) or less, Power Save: Silent
Voltage requirements:
Supply: Single phase 220 to 240VAC; Consumption: Typical 440W, Peak 1020W, Idle 140W (average), Power save <14W
Frequency:
50/60Hz +/-10%
Dimensions 1:
275 x 396 x 380mm (HxWxD)
Weight:
14.4kg
Warranty:
3 years extended warranty upon registration within 30 days of purchase. Without registration, the standard pan-European 1 year warranty applies
