If you need a black & white printer that supports extremely high levels of office productivity, without straining your budget, you need the B432dn.
A printer for every office
The combination of highly productive print speeds, excellent fine detail image quality for crisp, clear documents, and a design that complements working environments make the B432dn the perfect printer for every office. -
Exceptionally easy to use
Automatic two-sided printing; a LCD display, a low profile design for easier document retrieval: the B432dn will keep office productivity at a maximum, whether you choose the B432dn for fast personal printing or for sharing on the network. -
Impressive print speeds
The B432dn races through large jobs in minimal time. The first page prints out in 4.5 seconds and the rest at an impressive 40 pages per minute. -
Use it all day, every day
True 1200x1200dpi resolution means that all of your everyday office documents are printed with fine, crisp detail. An extra paper supply can be added, increasing the capacity right the way up to 880 and there is also a 100-sheet multi-purpose paper tray for feeding a variety of different paper types and sizes. -
Compact and efficient
The B432dn is specifically designed to meet the demands of offices. This unusually compact printer will fit in any office where space is limited. The toner cartridge and drum are separate units so you only ever have to replace what needs replacing so there’s no waste. -
Extra value
Other essential features include automatic two-sided printing as standard and a 2-line LCD display that tells you all about the current operating status of your printer. Sharing is made easy with Gigabit Ethernet or the optional wireless interface, while confidential documents are protected with PIN release secure print. -
Built for endurance
The B432dn uses ultra-reliable digital LED technology with fewer moving parts for exceptional durability.
- OKI B432dn - printer - B/W - LED
- Printer Type
- Workgroup printer - LED - B/W
- 12 kg
- Localisation
- United Kingdom
- Media Size Class
- A4/Legal
- Max Media Size
- 210 x 1321 mm
- Max Media Size (Custom)
- 210 mm x 1321 mm
- Print Speed
- Up to 40 ppm - B/W
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- Processor
- 667 MHz
- RAM Installed (Max)
- 512 MB
- Flash Memory Installed (Max)
- 3 GB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, XPS, PDF 1.7
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
- Total Media Capacity
- 350 sheets
- Media Handling
- 250-sheet input tray, 100-sheet bypass tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 500 - 5000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition
- 3-year warranty with product registration
- 24.5 cm x 38.7 cm x 36.4 cm
- Printer Type
- Workgroup printer - LED - monochrome
- Localisation
- United Kingdom
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- First Print Out Time B/W
- 4.5 sec
- Fonts Included
- 87 x PCL , 136 x PostScript , 2 x bitmapped , 1 x barcode
- Barcodes
- Media Handling
- Processor
- 667 MHz
RAM
- 512 MB
Flash Memory
- Flash Memory
- 3 GB
Media Handling
- Media Size Class
- A4/Legal
- Max Media Size
- 210 x 1321 mm
- 210 mm x 1321 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- 350 sheets
- Media Feeders
- 1 x automatic - 100 sheets weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets weight: 60 g/m² - 105 g/m²
- Max Media Capacity
- 880 sheets
Duty Cycle
- 80000 pages
- 500 - 5000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 3, IPP, HTTP, HTTPS, IPPS
- IPsec
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 600 Watt
- Power Consumption Stand by
- 80 Watt
- Power Consumption Sleep
- 1.4 Watt
- OS Required
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 55 dBA
- 24.5 cm
- 38.7 cm
- 36.4 cm
- 12 kg
