The B412dn brings productive, high quality black & white printing within the reach of every small business. With OKI, there’s no need to compromise between price and performance. You can have all the productivity features you need in a reliable, robust design that won’t stretch your budget.
Minimum expenditure, maximum value
The combination of the rapid print speeds, fine resolution for crisp, clear documents, and thoughtful design, makes this a printer that everyone will appreciate, whether you choose the B412dn for fast personal printing or for sharing on the network. -
Designed for ease of use
Once you start using the B412dn you’ll wonder why other printers aren’t built this way. It has a compact, low profile design, which makes it easy to reach out and pick up your printed documents, a backlit display for clear ‘at a glance’ information about the printer’s current operating status and consumables that anyone can replenish in a matter of moments. -
Consistent, affordable quality
The 1200x1200dpi resolution prints clear, pinsharp documents that are sure to impress. You will get full use of each consumable with no unnecessary waste. -
Extra value
Other makes of printers in this price range are often rather basic. But the B412dn distinguishes itself by including a range of added value features as standard, such as automatic two-sided printing, a 2-line LCD display and OKI Template Manager for quickly creating and printing on a wide variety of office documents. Sharing is made easy with the Gigabit Ethernet or the optional wireless interface, while confidential documents are protected with PIN release secure print. -
Built for endurance
The B412dn uses ultra-reliable digital LED technology with fewer moving parts for exceptional durability.
- OKI B412dn - printer - B/W - LED
- Printer Type
- Workgroup printer - LED - B/W
- 12 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 33 ppm - B/W
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- Processor
- 667 MHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Flash Memory Installed (Max)
- 3 GB
- Language Simulation
- PCL 5E, PostScript 3, EPSON FX, PCL 6, IBM ProPrinter, XPS, PDF 1.7
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
- Total Media Capacity
- 350 sheets
- Media Handling
- 250-sheet input tray, 100-sheet bypass tray
- Monthly Duty Cycle (max)
- 60000 pages
- Recommended Monthly Volume
- 250 - 3000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple OS X 10.9 Mavericks, Apple MacOS X 10.6.8 - 10.9
- 3-year warranty with product registration
- 38.7 cm x 36.4 cm x 24.5 cm
- Printer Type
- Workgroup printer - LED - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- First Print Out Time B/W
- 5 sec
- Fonts Included
- 87 x PCL
- Barcodes
- Media Handling
- Processor
- 667 MHz
RAM
- 512 MB / 512 MB (max)
Flash Memory
- Flash Memory
- 3 GB
Media Handling
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 350 sheets
- Media Feeders
- 1 x automatic - 100 sheets weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 880 sheets
Duty Cycle
- 60000 pages
- 250 - 3000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 3, IPP, HTTP, HTTPS, IPPS
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 560 Watt
- Power Consumption Stand by
- 80 Watt
- Power Consumption Sleep
- 1.4 Watt
- OS Required
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 53 dBA
- 38.7 cm
- 36.4 cm
- 24.5 cm
- 12 kg
