OCZ Vector 180 960GB 2.5" SATA 6Gb/s SSD
Quicklinx: B6SDWS00 Mfr#: VTR180-25SAT3-960G
Developed by OCZ, Vector 180 SSDs offer the superb feature-sets for the most demanding users. Featuring high performance, reliability, and endurance, the Vector 180 series provides a flash storage solution second to none. It's everything you know about SSDs, but better.
OCZ Vector 180 - SSD - 960 GB - SATA 6Gb/s
Solid state drive - internal
960 GB
NAND Flash Memory Type
19nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), shock resistant, TRIM support, OCZ Barefoot 3 M00 controller, Power Failure Management Plus, S.M.A.R.T., 256-bit AES, 44/1K bit BCH ECC
69.75 mm x 99.7 mm x 7 mm
115 g
5-year warranty
960 GB
2.5"
SATA 6Gb/s
69.75 mm
99.7 mm
7 mm
115 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 530 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
95000 IOPS
Maximum 4KB Random Write
20000 IOPS
Reliability
MTBF
2,300,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.85 Watt (idle) , 3.7 Watt (active)
Linux, Apple MacOS X, Microsoft Windows
UL, VCCI, C-Tick, BSMI, FCC, KCC, WEEE
Limited warranty - 5 years
70 °C
