Upgrade to a Trion 100 SSD and reveal a higher level of performance of your notebook or desktop system
The most awarded SSD brand of all time brings you the OCZ Trion 100 Series. Designed to optimize your notebook or PC easily and affordably, the trailblazing Trion 100 Series SSDs leverage premium Toshiba TLC NAND flash to go the distance and deliver a superior balance of performance, reliability, and value that will transform any mobile or desktop system.
Fast and Efficient
Up your productivity with the Trion 100 Series and enjoy faster boot ups, file transfers, and system responsiveness. Say goodbye to hard drive lag and get a state-of-the-art computing experience worthy of your time.
Performance Made Affordable
Upgrading to an SSD can feel like you’ve purchased an entirely new system—not only because of the enhanced speed, but also the initial investment normally associated with the technology. Trion 100 SSDs balance price and performance so you have enough funds leftover for other upgrades.
World-class Quality and Reliability
With 100% Toshiba technology built into every drive, each Trion 100 SSD is engineered for superior quality and reliability, keeping your data secure.
Better Battery Life
The more power-efficient Trion 100 Series is optimized for lower energy consumption which translates into longer battery life to keep you up and running longer.
Serious Speed. Zero Tricks.
Trion 100 offers plenty of real world performance for all your gaming and productivity applications. No fancy behind-the-scenes tricks, just pure storage performance.
Trion 100 SSD Features
Next Gen TLC Technology
Built with premium Toshiba TLC NAND flash
Superior balance of price and performance
World-class Quality & Reliability
100% Toshiba technology built into every drive, keeping data secure
Toshiba Controller & Firmware
Leverages Toshiba SSD controller technology
Better Battery Life
Optimized for lower energy consumption for longer battery life with built-in power management modes
OCZ's ShieldPlus Warranty
OCZ’s ShieldPlus Warranty is an industry-leading approach to service that eliminates all the hassle surrounding support and warranty claims consumers often have to deal with. No endless return loops, no shipping costs, and no hassle.
- High caliber customer service and support provided to customers
- Simply provide the SSD’s serial number
- In the event the product is determined to be defective it will be replaced with a brand new SSD
- Advanced product replacement and paid return shipping label minimizes expenses and downtime
OCZ SSD Guru - Unlock Your SSD's Potential
Introducing OCZ's New SSD Management Tool:
Dashboard: Real-time system status, capacity, health, updates, and more.
SSD Tuner: Increase write speed or adjust the over-provisioning.
OS Tuner: Optimize the way your OS interacts with your SSD.
Health Monitoring: Check in on how much life is left in your SSD.
Maintenance: Update your SSD’s firmware to enhance performance/stability.
Support: Quick troubleshooting and direct tech support links.
• 550 MB/s Sequential Read
• 530 MB/s Sequential Write
• 90,000 IOPS 4KB Random Read
• 64,000 IOPS 4KB Random Write
• 3-Year ShieldPlus Warranty
• 240TB TBW (Total Bytes Written)
• Toshiba A19nm Triple-Level Cell (TLC) NAND
• Serial ATA (SATA) 6Gb/s (SATA III)
• 2.5-inch, 7mm height
• Dimension (L x W x H) 100.00 x 69.85 x 7.00 mm
• Operating System - Windows / Linux / Mac OSX
Fast and efficient
Up your productivity with the Trion 100 Series and enjoy faster boot ups, file transfers, and system responsiveness. Say goodbye to hard drive lag and get a state-of-the-art computing experience worthy of your time. -
Performance made affordable
Upgrading to an SSD can feel like you've got an entirely new system - not only because of the enhanced speed, but also the initial investment normally associated with the technology. -
World-class quality and reliability
With 100% Toshiba technology built into every drive, each Trion 100 SSD is engineered for superior quality and reliability, keeping your data secure. -
Better battery life
The more power-efficient Trion 100 Series is optimized for lower energy consumption which translates into longer battery life to keep you up and running longer. -
Serious speed, zero tricks
- OCZ Trion 100 - SSD - 960 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 960 GB
- NAND Flash Memory Type
- 19nm triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Shock resistant, Toshiba A19 memory chip, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 48 g
- 3-year warranty
- Capacity
- 960 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 7 mm
- 48 g
Performance
- Internal Data Rate
- 550 MBps (read) / 530 MBps (write)
- 4KB Random Read
- 90000 IOPS
- 4KB Random Write
- 64000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 4.8 Watt (active) , 830 mW (idle)
- CSA, UL, C-Tick, BSMI, FCC, KCC, WEEE
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (operating)
- 20 g @ 10-2000 Hz
